Wheel hop cure. Need info
Anyway, Every revshift bushing that is offered in the rear (UCA, Cradle, Trailing arms, pinion), diff block, pinion support, G-force axels, Map/creative steel trailing arms (get rid of front rubber mount), BMR/Creative steel toe rods, good tires at right psi, should solve 99% of wheel hop.
I have everything but the toe rods and the wheel hop is largely gone. However, the more I beat on it the more lash and driveline slop I seem to have. I will be climbing under the car soon to determine if I need to do something with the ds bushing.
What size tires are you running?
Also would a stiffer strut/spring help? Seemed to make a big difference with wheel hop on my ~300whp FWD DSM when I put K-Sport coilovers on.
All in all, after tonight, I feel much better.
