CAM specs
I talked to josh at HORSEPOWER ADDICTS, told him my set up and goals. He suggested a 230/240 .612/.588 115 LSA with )*3 advance. My car isn't a DD and I wanted something on the aggressive side. I also wanted the power in the mid-range because of the Maggie running out of air. This is only a starting point, just curious of other ideas.
IdriveaV is that your silver V at his shop now. Yea Im new to CAM's so i wanted to see what other V drivers thought. Josh has done work on 3 of my buddies vette's with great results. I figured if im going to do a CAM i wanna see good results power and sound wise. Thanks, good luck with your V.
Interested to see what numbers you put down after the cam!
I know from the many times I've been to his shop he's had a few 112 & 122 cars down there.
