Whipple off, rethinking my next option
#42
That's more of a factor when picking a cooler, right? All of the Whipple head units I looked at were more or less the same height. Although the E-Force is lower, you will still need to clearance the corners on the front, IIRC. And there isn't enough displacement to efficiently boost a 427 LSX.
#43
Which will fit in the middle with my power dome hood, but at the snout it wouldn't clear even with my hood, I'd have to cut and fiberglass. So unless you want a scoop, I'm pretty sure your not going to fit it.
#46
Just fyi with the power dome hood I only need about 3/4" to clear the blower at the front, right above the water pump. Maybe even a tad less due to the fact that the supercharger narrows at that point.
I'm not sure if extreme composites gives any additional clearance.
#47
When broken motor mounts are present, I doubt that there's any change in the angle between the slave/clutch, or the pilot bearing/input shaft. This is because the bellhousing provides a strong/stiff/tough coupling between the transmission and the engine. If it didn't, flywheel torque would break the bellhousing or make it impossible to shift.
However, the shifter linkage can only tolerate up/down angles, because the joints can only rotate one way. A twisting or torsional moment caused by broken motor mounts may place a lot of stress on the shifting linkage, and may explain why people noticed that it was easier to shift after installing new motor mounts.
#48
Makes sense. Infact, when my poly motor mounts melted I probably lost almost an inch in height,(shifting was still good) my oil pan was resting on my swaybar. So you maybe able to get 1/2" or so lower from the motor mounts, any lower you'd be rubbing on the swaybar, less if you have a thicker swaybar.
Then you could shim the cradle, and get more clearance. You maybe able to get away with it, it would be close.
Not sure how far you'd be willing to shim the cradle, and I'm assuming you have a specter or EC hood already.
#50
I'm hashing out the details for the eforce, a forum vendor is looking into it, and figuring out pricing. I'll keep everybody in the loop as I find out more.
So far it looks like a viable and simple solution for those wanting an eforce.
#51
#52
This is awesome, Tommy! FWIW - another E-Force owner (Sssnake) recently got his LSA headed/cammed but otherwise stock LS2 up to 650 whp! I believe that was with the 3.5" pulley on 6 lbs of boost. Lots of promise here!
#56
It's all in the tune honestly. I've seen unsafe tunes that make less than stock power and blow motors. And I have seen tunes that are very safe that will increase power significantly.
#57
#58
My tuner (who has a ls2 v with maggy) said our stock bottom end is good for over 700hp. Not sure id push it that far but id think with a good setup n tune youre safe in the 600s
#59
The top piston ring gaps need to be opened up at a minimum. There is no hard rule as to how much power a stock bottom will support, there are too many variables.
I feel as if my stock bottom LS6 is on borrowed time at 10 lbs., however I don't do long Texas mile style WOT pulls either. I'll be going with forged pistons and rods and will then crank up the boost and see what she'll do.
