Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Ed Mod thread
Old 01-24-2014, 11:43 PM
BudRacing's Avatar
WES! My lower isolators seem to be glued to the control arm. How did you get them out without destroying them?
Old 01-25-2014, 12:44 AM
wes8398's Avatar
Mine weren't glued, but they were a bit stuck I guess. Just pry em out with a flat head screwdriver or something to that effect. Don't wreck em!
Old 01-25-2014, 10:19 AM
BudRacing's Avatar
I guess I'll have to try some heat on the underside of the control arm.
Old 01-25-2014, 10:58 AM
FoD
FoD's Avatar
Mine had some sticky material underneath that had dried up and no longer maintained its stickiness. But I believe they are glued from the factory. I used a flathead as well.
Old 01-25-2014, 11:33 AM
wes8398's Avatar
Heat shouldn't be necessary...
IIRC, there are also holes in the lower LCA, where you could poke something blunt-ended through and push the isolator out...
Old 01-25-2014, 12:20 PM
FoD
FoD's Avatar
^This.
Old 01-27-2014, 08:42 AM
BudRacing's Avatar
Worked like a charm. I was just too tired to fool with them that first night. Had been tearing down the front suspension for inner tie rods, a shock, a new rotor, ball joint...
Old 01-27-2014, 12:14 PM
wes8398's Avatar
Thumbs up
Quick Reply: Ed Mod thread
