Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Alcantara shifter boot for V1's - Group buy
Old 03-12-2014, 06:42 AM
  #101
CTS-V Shifter Sales
07CTS-V's Avatar
Originally Posted by 81LS1Camaro
Do you have any extra standard height ones left?
Unfortunately no. I purchased $700 worth of extra boots out of my pocket and they are all gone.
Old 03-12-2014, 08:44 AM
  #102
Eastern Regional Coordinator
CTSVBiggie's Avatar
Thank you again sir.
Old 03-12-2014, 11:12 PM
  #103
81LS1Camaro's Avatar
Thats a bummer, guess its motivation to be on the forums more. Its awesome that you ordered so many extra's for people though.
Old 03-13-2014, 02:10 AM
  #104
MarkOne's Avatar
Originally Posted by ChevyTrukRacer99
Sweet, I've got my V2 **** and new bushings. Now anxiously waiting for one of those pretty boots and your shifter.
You and me both! So far I've done the revshift tranny mount insert and while it did improved the slop in shifting, I know this short shifter kit will further enhance it.
Old 03-13-2014, 02:06 PM
  #105
ChevyTrukRacer99's Avatar
Yes. After this, I'll be doing mounts and bushings. Hopefully after that everything will be nice and tight.
Old 03-13-2014, 02:07 PM
  #106
I shipped all the boots today, except the ones that will be shipped with shifters. I have either emailed or PM'd everyone with tracking numbers.
ChevyTrukRacer99 - I'll be working on your shifter tonight and it'll be shipping with your boot tomorrow.
Did these go out?
Old 03-13-2014, 03:13 PM
  #107
90G60's Avatar
Did these go out?
Got mine yesterday. Please excuse the fingerprints on the ****.
Old 03-13-2014, 03:26 PM
  #108
MN_V's Avatar
Any tricks to the install after getting the shift **** off? Looks like there's just a surround on the base that holds the boot on.
Old 03-13-2014, 03:32 PM
  #109
90G60's Avatar
You have to pull GENTLY to remove the silver ring around the bezel. I used a small pair of needle nose pliers to squeeze the arms together then a small screwdriver to push them the rest of the way through. Then just pry up the flaps that are glued around the bezel. Getting it out was easy. Getting the new one to sit perfectly was not so easy.
It took 4 hands and several tries to get it just right. If you plan to glue the tabs back down (which you should) do it after everything is back together.
Old 03-13-2014, 03:52 PM
  #110
shadyLS6's Avatar
don't break the tabs on the trim, i broke mine and had to rebuild them with 2 part epozy and paperclips. pull from the rear of the boot.
Old 03-13-2014, 05:25 PM
  #111
isis's Avatar
My glue is drying now. Binder clips and goop is perfect. I also used needle nose pliers to pinch the clips. Bring it inside and let the plastic get warm too if it's cold out. It's GM standard quality plastic. Flexibility of a fortune cookie. I'll edit with a pic when it's dry enough to put back in the car.
Was dusky when I put it back in the car. Flash made it look weird. I'll try another time in daylight.
Edit:
Here we go
Thanks tho! Is really nice. I don't know how the stock one can be real leather and be so hideous.
Old 03-13-2014, 06:27 PM
  #112
MarkOne's Avatar
Is that a weighted shift ****?
Old 03-13-2014, 08:59 PM
  #113
MN_V's Avatar
What are you guys using to secure the new boot to the shift ****? It's not built the same as the stock leather and the clip can't compress the fabric enough. I tapped it down with a hammer after pulling the fabric as tight as I could but the clips can't engage. I threw the original rubber ring around it but not sure if it will hold longterm.
Here's a shot I took while taking the original apart. I did not originally remove the 'clip' part but just slipped the o-ring off after peeling the leather apart. The clip you see on top there serves to hold the o-ring on which the original boot is wrapped around and glued upon itself. I later removed the clip using a pick tool. A needle nose was just rounding them off and I was afraid of breaking them.
My guess is it will hold together as that clip is quite snug against the unfortunately short stalk of the shifter ****. Here's how she looks for now...
At this point I am not going to glue down the tabs in case I need to mess with it. Once the aluminum surround is reinstalled it is very snug and I don't see it pulling back up.
and +1 for the mini binder clips...
Old 03-13-2014, 10:52 PM
  #114
90G60's Avatar
Yup, it's the TWM Dessert Eagle. I hated spending $150 on a shift ****, but have loved it since the moment it arrived in the mail.
I cheated. The 54 inches short shifter (or whatever it's being called these days) has a threaded stalk which allows you to adjust where you want the boot to sit.
Old 03-14-2014, 11:49 AM
  #115
CTS-V Shifter Sales
07CTS-V's Avatar
Did these go out?
I shipped yours Wednesday with a short shifter. You should have it today or tomorrow.
Brian
Old 03-14-2014, 11:52 AM
  #116
Brian
Got it today. Everything looks great. Thanks so much.
Old 03-14-2014, 03:56 PM
  #117
isis's Avatar
MN_V: if you look at my pic above I have a rubber grommet I use as finishing trim. You could put it under the boot and hike it up. It fits on my modded stock shifter pretty snug but could grip even tighter with a zip tie. It's a generic "GM oil dipstick grommet" I found at autozone.
On other cars I've also pulled the boot up and put a zip tie on the shifter and wrapped it in electrical tape
Old 03-16-2014, 04:02 AM
  #118
serik21's Avatar
Looks ok I guess. 54inch short shiter
Old 03-18-2014, 10:04 AM
  #119
CTSVBiggie's Avatar
so yall have seen my shift ****. How do you think it comes off? Tried the method on teh FAQ. but I didnt get it moving.
Old 03-18-2014, 10:20 AM
  #120
Dmax/04V's Avatar
I had one of these on my 04 V and loved it, the TWM pieces are truly worth the money even if they hurt the wallet. That thing weighs about a pound and a half by itself, makes a huge difference in shifting.
Quick Reply: Alcantara shifter boot for V1's - Group buy
