fuel pump options
#41
I didn't know that the Hobbs switch was somewhat adjustable. That's good to know. I always liked your light indicator for the pump...the button was always the thing that gave me pause, but when you found those aluminum Oznium products, I was pretty much sold.
Something that I don't yet understand is how much boost (if any) a heavily-overdriven supercharger might make below 2000 RPM. It would be a waste of time and money building/installing the relays, Hobbs switch, and indication lights if both pumps are going to wind up run continuously. It's just something else I have to check on.
#42
mine is overdriven as you can get and watching the gauge during normal driving i rarely go into boost part throttling. any stab at it will instantly go into boost but thats obvious.
depending on your boost level and the fact that full boost comes on instantly id run a hobbs switch thats set for about 50-60% of your max boost.
#43
The single DW300 can probably handle 3-4 psi boost however, a positive displacement SC makes full boost extremely fast - like instant. You have to 'fuel follow'. Stomp on the gas and you loose some pressure because you're motion, within a couple seconds you are at full boost - setting the trigger low like at 1-2psi boost enables the secondary fuel pump to maintain volume and pressure.
You have to think of two scenarios - part throttle & WOT. It is safer to have that trigger set right when boost happens. You can always change out the Hobbs with something different but I would start at 1-2psi. You can change them out in the same amount time it takes to change light bulb.
![](http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-10-26194739_zps3b6eb805.jpg)
This is an older pic but you can see where I installed the Hobbs in the vacuum manifold. I have everything completely wired since this pic. You can just unplug the Hobbs and unscrew it - reverse that for a higher pressure one.
