Drive shaft Opinions please
Fuzzy has a temp strip in his trans tunnel. I've seen it in a few pictures. Is probably be hard to see it unless you lifted the car and got under it right after running it hard.
My .01, Save your money for the driveshaft, get the CS 8.8 bracket, axle, rear cover and driveshaft kit, build your own centersection out of a junkyard housing, and when you order the driveshaft with the 8.8 kit, get the DSS 1 piece aluminum. I helped design to clear any aftermarket shifter. Unless you are doing the texas mile with 800=hp, i really dont see the need for more. I did not get the Carbon Fiber because temps above 300 F can affect the bond on the carbon fiber where it meets the ends. And, our exhaust runs right under the whole length of the shaft.
Heat shouldn't be an issue.
