Alt charging problem
So my alt is not charging. Took it off & had it tested @ the local parts store, It checked out good so i had them check it again to make sure & it checked out good again. I put it bk on the car & it still was not working. After lookin on the Internet i found out that the orange wire that plugs into the alt should have 12 V on it, it didn't. I made a jumper wire to the batt & it started charging. Can anyone help me out with a wiring diagram of where this wire gets its voltage from & is it a fusable link?
Ok i will check that. Just to make sure that we are talking about the same wire, I am referring to the plastic plug with the two wires that plugs into the alt not the main wire that attaches to the wire lug on the back of the alt.
The LS2 V1 does have a fusible link behind the driver's side exhaust manifold. You should check this wire and the wires in the connector. Pin B - orange wire is the "turn on" and C - gray wire is the "duty cycle". Pin B should be high 12V or more and PIN C is a varying voltage. I believe this is common on the LS1 and LS2 but know it is correct for the LS2 (rewired the alt this weekend - Big Three).
Yes that is correct. Pin-B Should have 12V But it doesn't. I need to figure out where the orange wire gets its power from?
