Transmission noise - video inside
Hi guys,
My V makes this weird noise from the transmission area after i've warmed it up only a little ~125. The noise happens when I try to shift into the gear and it's blocked (so i disengage and re-engage the clutch and the gear is not blocked this is when the chirp is heard - video 1) or when i'm in gear and i'm lightly letting off the clutch to get moving(as you can see in video 2) The noise continues until i either take it out of gear or fully disengage the clutch and get moving.
The V has almost 90k miles and i'm not sure if the clutch has ever been replaced and if this is a sign of a clutch needing replacement. I am also not sure when/if the clutch fluid has been replaced but it is not low. I was looking into buying the aftermarket master cylinder sold by philistine to fix the blocked gears but before i do that, i would like to know if i have a bigger issue or if my clutch needs replacing.
both videos the car temp is at around 120-140. The noise is completely gone when the car is up to normal temp.
Video 1 - This is me simply engaging the clutch, attempting to go in a few gears, disengage and repeat
Video 2 - I put the car in reverse after some failed attempts and let off the clutch to get moving
Yeah it's topped off, but like i said i'm not sure if/when it was replaced since i recently bought the V. I was going to do the new fluid but i've been holding off in case the problem is the master cylinder or the clutch itself.
Judging by your videos, it looks like disengagement issues. I would first bleed the system to rule out any air being trapped in there.
Regarding the clutch, it's a guessing game since you don't know what's in there. You can spend a day tearing it apart to investigate and replace the slave while you're at it and install a remote bleed line if you don't already have one.
I got you covered if you choose to upgrade to one of my performance clutch master cylinders - I have 5 complete kits ready to go from the latest batch.
https://ls1tech.com/forums/cadillac-...g-process.html
Tons of feedback on this link:
https://ls1tech.com/forums/cadillac-...-cylinder.html
Thanks for all the input guys. I am ordering a motive power bleeder to do my clutch fluid and go from there. I will post back with results once i've flushed the system.
I meant engine coolant temp, i guess i just said that to mention that it was essentially when the car was still cold.
So I got the motive power bleeder in and changed the fluid. Very easy to do other than when I was tightening the bleeder valve the hose came off and I bathed myself in clutch fluid.
The fluid was a nasty black color so i'm happy to have some new stuff in there. Unfortunately it didn't fix the issue and the noise is still there so now i'm looking into what my next step should be.
