Normal engine temp?
I generally see around 210, 220ish on average. I don't worry much about 230, 240. I've never seen higher than that.
http://articles.latimes.com/1992-03-...uminum-engines
You also have to take into account I been messing with cars too long. The Aluminum LS motor is head and shoulders above anything we had in the 60's and 70's, but that is because of engineering not materials. Aluminum is light if designed right make for a strong casting, heat kills it strength and stability.
How bout we do this... Ask what motors are in Prototype Challenge cars in the Tudor endurance races? 6.2L sealed Chevy blocks. 450bhp all the same... Every single one... Daytona, 24hour race, trans failures, suspension failures, crashes, I don't remember one being retired due to an engine failure. The C5r, C6r, C7r, all aluminum blocks. The only blocks that are still cast iron these days are diesels. I really can't think of a new car that has a cast block that isn't a diesel. Its 23 years after that article was written. Trucks are different, but even most of them are getting aluminum blocks now for weight savings. Heck, the deltawing has been experimenting with a carbon fiber block... Carbon fiber with steel sleeves. Aluminum is old news now.
I would flush your rad out, change your thermostat, use a 180, and dont bother tuning the fans.
use premixed 50/50 from caltex or another decent company, not gm. And then add a bottle of radiator relief from DEI.
I think the cost of allowing air to move over the radiator instead of forcing it through is apparent and probably counterproductive. Sure the outside of your engine may be slightly cooler but the inside would be hotter.
I did take note of the weather stripping removal. I might try this and see once summer rolls around.
Definitely going to try something before I go head to head with Johnny O........ha!
