Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
V1 5 lug swap [complete]
Old 03-16-2015, 08:33 AM
  #41
Bio248's Avatar
i've got my fourth bearing in. totally different than the other three. hilarious, right? oh well, they're all the right part numbers so they should be usable. we'll hope the quality is on par with what i actually ordered, heh.
still waiting on hearing back about a base CTS ebrake assembly. then i just need to order the V backing plate and swap those on and i should have my ebrake setup ready to go. rotors are gonna come from these guys as well.
then i just need TPMS and tires. it's starting to get warmer up here in wisconsin so i need to start getting a move on otherwise i'm just gonna wear out my winter tires instead.
Old 03-16-2015, 08:41 AM
  #42
Naf
Naf's Avatar
You are gonna need more parts...
IF YOU SEARCHED like to told you to, you would have found the list in my Makin Progress...
I did all the leg work, you just needed to click those tiny little fingers and you would have found this list
Parts you will need are
25814678 - x2, shoe kit
25867413 - x2, shoe lever arm
25867414 - x2, shoe leveler
18K2087 - spring and hardware kit
25851190 OE Service Rear Brake
25851205 OE Service Rear Brake
HAVE FUN...Seriously, there is a search button USE IT...
Old 03-16-2015, 08:53 AM
  #43
Bio248's Avatar
i copied and pasted the parts list from your thread into my first post already.
the entire parking brake assembly, except for the backing plate, from the base CTS is the exact same stuff. if i have the entire assembly then all i need are the new backing plates, which are $75 each on amazon.
i haven't been able to track down all of those parts separately, that's why i'm having a hard time. i'm also not sure i want to pay dealer prices for any of it based on the rape factor of their costs.
Old 03-17-2015, 12:32 AM
  #44
Naf
Naf's Avatar
contact luke at lindsay caddy. He offers the best prices on gm parts...
or rockauto
or even ebay.
Old 03-17-2015, 07:55 AM
  #45
Bio248's Avatar
rockauto's shipping prices are astronomical. and i couldn't find the complete list of parts there, ebay, or amazon. i'm just missing a piece or two, that's it.
maybe i'll give luke a ring and see what he can offer.
Old 03-17-2015, 08:50 AM
  #46
Naf
Naf's Avatar
What parts are you missing? The OEM cables clip right in...
Old 03-17-2015, 08:52 AM
  #47
Naf
Naf's Avatar
These are the parts from the V2 for the ebrake
E-brake
25851190 - backing plate
25851205 - backing plate
25693149 - cable bracket
25693150 - cable bracket
25814678 - shoe kit
20823795 - cable
20823866 - cable equalizer
18K2087 - spring kit
Raybestos H7363 - hardware kit
Old 03-17-2015, 09:22 AM
  #48
Bio248's Avatar
so is the parts list you have listed from your thread all of it or not? does anything else that i need not transfer over from the stock stuff?
edit: looks like i'll need the bracket for the cable since the bracket stock is part of the backing plate.
Old 03-18-2015, 01:03 AM
  #49
Naf
Naf's Avatar
To properly convert to a 5 lug system and not redrillin your rotors, which is a bad idea, these are everything you will need as well as the V2 rear rotor...
Everything will fit in properly and at full safety
Redrilling your rotors for the new configuration though possible is not safe at all.
Old 03-18-2015, 06:37 AM
  #50
Bio248's Avatar
right, so i've got the line on the V2 rear rotors already (same as camaro anyway). front rotors from a camaro since i'm not going to the 6 pot front calipers. easy.
but basically besides the list i copy/pasted above from you, i'll also need the cable brackets in order to make the parking brake assembly appropriate.
Old 03-18-2015, 09:00 AM
  #51
NIKDSC5's Avatar
Every time I come into this thread is makes me happy that I don't care this much about wheels The $ and time and parts of this thing.... I have other projects......
Old 03-18-2015, 09:21 AM
  #52
Bio248's Avatar
if i cared about going faster i'd still have to do this because the wheel choices severely limit tire choices. once step at a time, dude.
rotors, front and rear, purchased.
now i gotta figure out pads, TPMS, and tires. the ebrake parts i'm just waiting on the rest of the 'quote', then i'll call in and order.
Old 03-18-2015, 09:53 AM
  #53
NIKDSC5's Avatar
Even with that though where is all this tire going?
Inward? Not much going there, and I have a set of stock wheels I plan to widen as much as possible once I setup my suspension and measure.
Outward? Same thing, prepare for body work.
I know I can get 9.25" rim and a 295 drag radial (shooting for 10" with out a spacer) so how much more tire do you need? a 295 drag radial or a good comp r tire will give all the traction necessary for 800+. If making more than that say 1k range you'd mini tub and widen and the whole shebang.
basically, IMO this is only for more options for visual wheels. I have a hard time jumping on board your traction argument. Even now stock I can get a 275 drag radial.......
Edit: Bigger tires don't make up for shittier driving. Look at Viper owners.
  #54
ls1247's Avatar
I get happy because it looks like this swap is getting closer and closer to an off the shelf, junk yard and parts counter build with no machining required. I'll have to reread this several times but if IIRC, all the information is in here to make that work.
Old 03-18-2015, 10:21 AM
  #55
Bio248's Avatar
here is where you're losing me.
those wheels in 6x115, or widening the stockers, is going to cost you just as much as doing what i'm doing right now, if not more.
it'd only costing me as much as it is because i'm doing my best to use quality parts and doing it as bolt on as possible. i could be done already if i just wanted to redrill my stock rotors and be ghetto about it. then i'd have my choice of a million different options for large 5x120 wheels at discount prices.
then we're both in the same place with the wheels/tires fitting. going inwards is stupid and i'm not a rookie with a fender roller. so basically we're saying the exact same things, but i'm doing something about it.
Old 03-18-2015, 10:28 AM
  #56
ls1247's Avatar
I thought widening the wheels was like $250 each...sounds like a wash really.
Either way, are you going to go with the CS trailing arms? IIRC, a stock wheel at 9.75" would work with a set of these and no telling what you can get away with using aftermarkets on a 5 lug pattern....some of us would rather run a wider tire than being forced to use a drag radial or comp R tire all the time so going wide would make sense for some.
Old 03-18-2015, 10:35 AM
  #57
NIKDSC5's Avatar
Widening my rims will cost me less than what your "winter" wheels cost you So its not a wash either since you have so many other parts working in this.
Why would going in be stupid? And a fender roller won't net you what i think you're hoping it will.
What am I not doing about it? I have my plan.
Also, with the CS trailing arms ls247 the next closest thing to hit will be the coil over.
Old 03-18-2015, 10:38 AM
  #58
Bio248's Avatar
i have the CS trailing arms already, not installed. that's not the big issue.
you can go in only so far unless you want to cut stuff up. that's fine, but i don't want to.
pulling the rear fenders is a lot easier and will give me more than enough room to run the piddly 275s i want to run anyway. it's a street car and it'll never be tracked.
if you can widen your wheels for that cheap then do it. i know there are places out there that do it and it's not something i wanted. i don't want the same CTS-V that everyone else has.
i'm just opening the doors here. i don't know which one i'm going to walk through in the future...
Old 03-18-2015, 10:41 AM
  #59
NIKDSC5's Avatar
Fair enough. I run 275's on the stockers currently. At the track and road course, they work just fine. Not ideal, but operable.
Old 03-18-2015, 10:42 AM
  #60
ls1247's Avatar
I like a wider tire from a cosmetic standpoint but I also like the stock wheels. Was thinking about rolling the fenders, using a 1/4" spacer on longer studs, the CS arms and 9.75 inch widen stock wheels running a 305 tire. This should work but before pulling the trigger, I'll research it again....you get conflicting stories....
Quick Reply: V1 5 lug swap [complete]
