Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
CaptSlow's Log
Old 02-19-2016, 11:00 AM
BudRacing's Avatar
Originally Posted by CaptSlow
...and yea, way to go GM, giving us a base models rear end, freaking morons.
i can imagine the conversation going like this:
"let drop a 400hp v8 in the CTS."
"how are we going to strengthen it to handle the extra power?"
"give it a 6-lug hub setup."
"you don't want to upgrade the rear end?"
"nah bruh.... Getrag. it'll hold."
"We'll just put 3 levels of soft rubber bushings to support it"
"The base model drive shaft is the real weak point."
"Yeah, let's put in a non-serviceable two piece with a center bearing supported by a thin rubber ring."
"Word"
"Oh, and the motor mounts. How can we stop vibrations? We've never been able to do that before."
"Let's try these hydraulic filled sacks of heat susceptible rubber and put them right under the exhaust manifolds."
"Genius!" *high fives exchanged*
Old 02-19-2016, 12:41 PM
black06g85's Avatar
you've been working on the TA for what?..... 3-4 years now?
my plan for "stage 1" performance mods are:
OBX headers w/ high flow cats
muffler deletes
'homemade' k&n intake setup
ported stock throttle body
dyno/street tune
5 1/2 years lol.
it's almost there though. setup changed about 4 times mid build that's why it's taking forever lol.
finally got all my parts together to finish the build, just waiting for the temps to go up. getting old, hate working in the cold lol.
Old 02-19-2016, 12:56 PM
CaptSlow's Avatar
"Word"
exactly!!
Originally Posted by black06g85
5 1/2 years lol.
well if i lived closer i'd come over and verbally assault you until you got your lazy/fat butt out there and finished it.
then promptly call 'dibs' for the first ride in it.
Old 02-19-2016, 01:28 PM
black06g85's Avatar
haha it's not that far a ride.
got some wiring to finish up in the cobalt for the nitrous and pre-turbo meth to get that thing on the dyno next saturday (hoping for 550ish boost only, 650whp on spray), then it's back to working on the trans am. Thankfully I don't have anyone else's car to work on anymore so now I'll finally have time to work on my own. got stuck in 10 other people's projects over the last 2 years which severely limited my time to my own cars.
hell even the cobalt sat for almost a year before I got it back up and running.
trans am is getting there, all that's left is:
power and ground to holley efi
power and grounds to fuel pump relays
front brake lines
bolt the converter to the flexplate, install drive shaft, fill trans
bolt in front coilovers
bolt what's left of the dash back in and seats.
weld in door bars and tabs for the harness
then it's time to rock and roll.
Old 02-19-2016, 07:26 PM
isis's Avatar
650 fwd Whp? Why do you hate tires?
Old 02-21-2016, 05:54 AM
black06g85's Avatar
makes for a fun work car, I commute 150 miles rd trip everyday. it hooks up eventually....... around 120mph lol
Old 07-22-2016, 01:49 PM
CaptSlow's Avatar
well.... 5 months later and NOTHING has been done to my V1 since i posted this.
but that'll all change this weekend. the 8.8 setup, cradle bushings & Brian's Hurst shifter will all be installed. woohoo!!!
Old 07-22-2016, 02:12 PM
BudRacing's Avatar
Is that also a driveshaft I see? or are you hanging curtain rods this weekend too?
Old 07-22-2016, 02:20 PM
CaptSlow's Avatar
haha! yea i went with the 1-piece aluminum option.
Old 07-22-2016, 04:32 PM
jcollege's Avatar
Should be a fun weekend ahead of you!
Old 07-23-2016, 06:43 PM
CaptSlow's Avatar
A mechanic friend did the install today, finishing it up tomorrow......
Got a situation tho, he said the stock exhaust is hitting everywhere. Any ideas to fix this outside of letting the exhaust hang??
Old 07-24-2016, 12:11 PM
  #32
BudRacing's Avatar
Hitting what everywhere? The new driveshaft?
Old 07-24-2016, 12:44 PM
  #33
ls1247's Avatar
Mine hit on the front mounting bolts and down the side of the diff on the drivers side...heat and beat.
Old 07-25-2016, 05:34 AM
  #34
CaptSlow's Avatar
yea apparently the entire heatshield on top of the resonator was hitting the driveshaft..... removed it (for now) and there's now plenty of room.
then it's hitting the 8.8 housing on the driver side and the one "lower" mounting bolt on the passenger side.
she sure is purty tho
Old 07-25-2016, 08:49 AM
  #35
jcollege's Avatar
What exhaust are you running? I piecing together my 8.8 kit, im sure I will have to dent my exhaust after looking at these pics.
Old 07-25-2016, 10:38 AM
  #36
CaptSlow's Avatar
my car is completely stock.
Old 07-25-2016, 12:48 PM
  #37
BudRacing's Avatar
It looks like you have the resonator replaced with either an H or X (can't tell which). It's possible that could have slightly changed an angle of that exhaust line. Either way, the 8.8 is a wider setup than stock.
Also, your car was completely bone stock.
Old 07-25-2016, 01:25 PM
  #38
jmilz28's Avatar
...heat and beat.
Someone needs to address this properly...
Old 07-25-2016, 03:30 PM
  #39
CaptSlow's Avatar
yea.... WAS.... so down the rabbit hole i go. haha!!
i promise that the entire exhaust is stock, for now.
properly = sober? it'll be done right.
Old 09-16-2016, 02:00 PM
  #40
CaptSlow's Avatar
so for the first time in over a year...... i'm going back to the track tonight!!! woohoo!!!
last year i went, ran some crappy times.....
since then i've replaced the engine & transmission mounts along with new cradle bushing and shift........ oh and i slapped in a CS 8.8 setup.
Quick Reply: CaptSlow's Log
