2005 CTS-V Stock Injector Size and HP on stock Fuel Pump?!
Got a 05 V coming for Full Exhaust and CAI and a Cam swap...
Wondering about the fuel side of it and if ill need injectors and pump
Thanks!
Thanks!
I'm on stock pump. She sig.
Stock injectors I believe are 36's and are good with full bolt one and cam. Once you do intake and head work the stock injectors begin to run out of steam
Stock injectors are 28lbs and will be fine cam only. If you do a FAST intake you will need bigger injectors...... fuel pump will get you to around 500rwhp. The stock clutch will be fine, I beat on mine with nitrous and a cam for a while and it never gave me a problem.
I live at sea level. Got a medium sized cam, fast102, and lontubes. Haven't seen even 90 percent duty cycle yet. Find it hard to believe a cam and fast will put you near 100 percent duty cycle.
Don't think you're going to gain horsepower by simply using larger injectors. I'd think any gains from injectors will be negligible at best... I mean maybe aftermarket injectors will atomize the fuel better.
The reason is because... LS2 injectors are larger and won't need to have injectors replaced. LS6 injectors are smaller and the potential to need them replaced is increased.
Originally Posted by serik21
Wrong again. Smh. Will this ever stop.
Ls2 injectors are good for about 430whp after there that will be around 100 duty cycle. Also ford racing uses Siemens injectors which are plug and play for our application.
The ford racin has a narrower spray pattern than the bosch, and in NA you want a wide pattern to maximize the atomization of the fuel...
Fix
Or
Repair
Daily
FORD...
How any V can have Heads/cam/intake and be on stock injectors is beyond me.
In my books that is a double win.
If you buy them from brutespeed aka bob one of the first guys to develop a procharger kit for v1 he provides injector data.
