I need new pads and rotors 07' V.
#61
#62
The front seem ok so far and still have alot of pad left, but thier noisy.
And im only running these autozone stuff cause they came with the car when i bought it, brand new , just werent installed so when the other brakes were goin out i put these on
#63
I use Hawk Super Duty pads and Centric rotors on my Suburban and 4Runner with excellent results, now almost 50k on the old 'Burb's brakes, unheard of on OBS trucks. I used to use HPS on my Camaro and get 40k with great braking until death...but they did dust a lot. I've seen evidence that the HPS 5.0 is a meaningful improvement over the old HPS compound and will go with that. Example: Strano used to recommend HPS as a great street pad but now recommends HPS 5.0. There are lots of good brake compounds out there and Hawk is one of the 3 or 4 brands Sam Strano recommends...good enough for me. Know the tradeoffs between ceramic and composite compounds before breaking it down further.
#64
#65
Never do cross drilled, weakens the structure and removes mass from the heatsinks/rotors. I'd consider slotted for a track car or low mileage car. Check the C7.R brakes FWIW. For a driver, high quality blanks are the way to go.
#66
If that Amazon deal is set up the same way it has been in the past, it'll only give you a discount on a single item ("Save 20% on 1 of 1 ACDelco brake parts..." is what it says when I hover over the promotional offer at the links above). When they did the discount last July, I ordered front and rear rotors - 4 items, 4 separate orders to get the discount on all 4.
The 20% off ends at the end of the month, so get 'em while they're hot!
