Low oil pressure
Low oil pressure
Just had a rebuild on an ls2 V. Before the rebuild a new pump was installed that would read low oil pressure around 10psi when hot and 25 when driving.
Now that the motor has been rebuilt (stock everything) except .020 pistons it is still reading 16-17psi idling (will eventually go down to 13 idling) and 27-31psi when driving. It was reading around 25 while driving but changed the oil then went up to 30 after driving it for 200 miles. According to the mechanic it was suppose to go up as everything broke in but I don't think that's right.
Maybe a wrong o-ring? The same exact brand pumps were used now and before rebuild which is why I think maybe it could be the wrong size o-ring.
None of this sounds good. Oil pressure will not rise as an engine breaks in from my experience. At least not double or more which is what I would need to be comfortable. Check it with a mechanical gauge.
Could be wrong or damaged o-ring, loose clearances, etc. O-ring probably easiest to check but mechanical gauge first IMO.
Did you use the same pump post-rebuild? Pump could be bad or wrong/dirty bypass spring/orifice as well.
Ok I'll try to check it with a mechanical gauge. Different pumps but both same brand which is why I'm thinking it has to do with the pump/o-ring (maybe wrong o-ring). My old one gave out, so I replace it with a new one but it never read as high as the stock one.
Now on the rebuild this new pump is doing the exact same thing that the first replacement was doing. It's a sealed power oil pump from rockauto.
Can I use the autometer adapter for the mechanical gauge?
http://shop.advanceautoparts.com/p/a...FQRehgodL5EEuw
Yes. Summit seems to concur. I used one of these but had to check to make sure I had the right part#:
https://www.summitracing.com/parts/ATM-2268/
I almost want to just go ahead and order an oem one from tasca parts but I'm gonna wait to check it with the gauge first. Thanks I hope I don't have to either!
