What tranny will work on 2005 ctsv
I just buy a CTSV that had no motor but came with ECU and wiring harness just bought a 2004 Pontiac GTO motor got it for you Bill now trying to find a transmission found a 2007 CTSV transmission will it work no problems no modifications
Can you take a few pics? I still have mine out and can compare them. I know 04 and 05 are the same, the bell housing will be the same across 04-07. I dont think there should be much of a difference
Even if he had a pristine dual-mass(stock V) setup, would any of you actually recommend using it?
Thanks for the help guys.
PS: Since this will come up eventually anyway, what will the OP encounter with front accessory drive setup? I have seen evidence of the GTO spacing being slightly different from V(/Vette?). Is there room for the GTO stuff?
If using the LS1 style clutch, slave, throwout bearing, it should work though right? (shorter clutch, but longer slave to make up the difference) Change of pilot bearing I think is required due to the V input shaft? Is there something more specific about the GTO unit I am unaware of?
You are too quick. I was adding(editing) this in my post:
Also I am in Vegas for a week so no pics until I return. But..Bone stock 2007 V. And I just threw out my stock dual mass setup this past weekend. Holy mother of God that thing is heavy.
Hes putting a whole engine that came out another car, there will be some modification needed and maybe some extra wiring to be done. I am sure regardless the engine will fit in. It would be easier if he had the old engine and swap everything from the old to the new. Im sure the knock sensors, pressure and position sensors are the same. What I dont know would be the alternator wires, starter wires, those connectors that go to them and any other extras that the GTO has that the CTS-V doesnt and vice versa. It is going to be attention to detail with this swap to see what he needs or dont. But for the engine and tranny, they both should bolt up just fine if he is using the cts-v bell housing. I dont think he would even need a tune how closely similar the engines are
All good points. I am specifically targeting accessory drive spacing. I think GTO is a little further out from the block than the V. I think V/Vette is the closest, GTO/F-body somewhere in the middle, and Truck/LS3 the farthest out. Don't know how much it differs between GTO and V to know if the accessories will have a clearance issue in the front. Nothing to do with the transmission; just trying to help the guy know what he is getting into.
I wasn't aware the gto ever came with an LS6... Only ls1 and ls2... I could be wrong. Also I was thinking the bellhousing on the V1 transmission was longer?? Now that I typed it, I feel I may be wrong on that lol.. if it was me, I'd use an LS2 flywheel, clutch/pressure plate, and slave which is believe is the same units for all the vettes, z06 included... Something about the ls1 flywheels and balancing... My God, I'm out of the loop on this stuff anymore. Dang driveshafts got my brain all occupied. Sorry lol
If the GTO accessories are farther forward, there could be some fan shroud clearance issue, particularly around the water pump domed pulley. I replaced my water pump with a C5 Corvette pump (~$100 less) and a bracket on the shroud needed some slight clearancing. Not a whole lot of room to play with there.
This is true. The LS6 was not offered in the GTO. LS1 in 04 with the single side exit exhaust. At that point they may have had the LS6 intake manifold... but not the 243 heads. Similar to the last models of F-bodies. Then in 05 they got the truck motors with dual exhaust exits. I believe they were using the last of the LS1 stock in 04. Similar to how they used the last of the LS6 stock for the V in 04-05, then switched to the mass produced LS2.
So the 2004 gto motor probably won't work in the 2005 ctsv
I'm not the best at working on cars but I can put a motor in and a tranny just don't know what I'm getting into with this work I have the stock wiring harness foe the v and ecu was hoping I could just drop the motor in and a 2007 ctsv tranny n hook everything up n be on the road
If you had an LS2 wire harness and ECU from a 2006-07 V and ls2 engine from a gto, AND all the accessories from an LS2 Ctsv... You'd have an easier time. If you run the Ctsv ECU (for an LS6) it's probably not gonna work straight away with the ls1.. without tuner changing things.
