Loose steering?
Loose steering?
So I have a big dead zone 2-3 inches of free play in my steering when you turn the wheel. Had a bad wheel on the front that gave me vibrations for a while but once I had the wheel fixed they are still there somewhat. Rocked the wheels from left to right with them off the ground and there is a tiny bit of wiggle but it's hard to tell. Any ideas?
Wheel was fixed it was a decent amount out but nothing crazy. The front subframe bolts also dropped on the front of the car right after I bought it, two front bolts missing one rear snapped and smack! But it was always had a vibration I attributed to the wheels but a bad tie rod will cause that kind of vibration and the alignment wonders just a touch. But I still have the vibration in the wheel and after the wheel was straightened I noticed the dead spot or loosens of the steering wheel travel. Have to leave town butt early Friday morning and want to take the v. May have to give in and have it thrown on the alignment rack in the morning for a definitive answer
Has to be in the rack or the steering shaft. Had it on the rack this morning and no dice. Everything was tight and good.
Have you ever had bent wheels? The tire shop said all my wheels where bent so I began having them fixed. One was straitened on the front and I bought a used one also for the front as it was bent on the face. But if my rear two are still bent would they vibrate through the entire car?
Have done lots of trouble shooting and most of the vibration can be balanced out but it requires them to have it most of the day. Stuck my spare on the rear and my *** vibration is reduced significantly so I am going to pony up and have the rest of the wheels check and straitened if needed I know it's not drive line related after eminence investigation but I did have an interesting thought brought up. If I didn't put a big enough dent in my primary for the header it could be causing my intermittent steering wheel vibration....... ordering a new shaft and will get a bigger hammer out when I get back. Mildly pissed I have to take our dodge on a road trip. I mean it's a dodge.
I watched your video and it sounded exactly like a problem I had. Naf pointed it out as well... The steering shaft. Double and triple check the ujoint in the steering shaft. When I bought my V and was driving the 5hrs back home...I noticed the same thing, couple inches of dead play in the steering wheel and that clinking noise back and forth.. ultimately I found a missing cap on the small ujoint in the steering shaft. New shaft fixed the problem.
Replaced part of my steering linkage the upper slip joint at the firewall. There was just a little clunkyness in that universal joint but apparently that is enough to make that big of a difference.
Eliminated a lot of my steering wheel vibration got a little more clearance from the header but it had enough it should have not been an issue. Anyhow was enough I could narrow down the rest of my vibration is coming from one of the rear wheels. Took out 90% of my steering wheel slop. Happy camper for today.
