Group Buy Feeler: Flat Steering Wheel and Fast Ratio Steering Rack
This is just a feeler. I'm pursuing these upgrades for myself regardless of public interest and will be paying a lot to make it happen.
The wheel won't be available until August. It'll cost $695 and require a core exchange. You *may* have the option to maintain the original diameter or choose a reduced size (~1" smaller). It'll have larger thumb grips and more padding. Haven't nailed down the leather options yet. No modifications will be required to install--plug and play. You will maintain your steering wheel controls and airbag.
The steering rack will cost about $2000. You'll have options of 14:1, 12:1, and 9:1 Saginaw 800 series box. Proprietary design for the V1, but you'll be able to source replacement parts freely once you have it.
I'd love to have a quicker rack - particularly on track, the slow steering makes the car feel sluggish. But I don't think I'd love it $2000 worth.
The OEM power steering pump starts to cavitate above 4000-5000 engine RPM, which further reduces its flow rate, and boils the fluid to the point where you're liable to melt the rack o-rings. You've gotta give GM credit--they know how the majority of their customers drive their cars and engineered that pump to be as cheap as possible without requiring an excessive number of warranty claims.
Interesting...
I'd like to see some pictures of the steering wheel, but I would love to get a faster rack in this car. It is the one thing that is giving me thoughts about selling my car. The stock G8 steering is so much better than the V it's not even in the same category
By chance does anybody know what a V2 rack has for ratio? The V2 cradle does bolt up to our cars FYI
Interesting...
Magnasteer (a term you're probably familiar with) provides increased resistance as you drive faster. This makes it easier to stay in control at highway speeds. Also, the rack ratio becomes faster as you roll away from the center area. The idea was to make it really easy to drive straight at speed, but also provide a fast ratio to assist with parking.
Did you just say that you can confirm the front V2 cradle will bolt to a V1? I think this is the first i have heard this. Do you also know if it will mount a v1 rack to it? Beyond that the only other thing i can think of is the LCA's being mounted in the same geometry?
The ABS pump can have a bracket made for it clearly as the location isn't critical.
Other than that, yes I am interested in a steering wheel, and maybe a rack, but that cost is a high bar to entry especially if you are talking about running a new pump as well and spending 8-900 on that.
The steering rack V1 to V2 has different mounting holes in X,Y,Z locations so you'd have to run the V2 rack in a V2 cradle. There is also a slight angle change for the steering yoke, so might have to run V2 steering linkage possibly (need further investigation here). I'm trying to find the C-factor difference between V1 and V2 to see if this is worthwhile improvement in response. The V2 LCA's geometry look like they will help in that department too.
The V2 LCA's are in different locations but the hub centerline when combined with the V2 knuckles overlays exactly where the V1 hub centerline is. I need to confirm UCA placement in the V2 vs V1 body to make sure those can bolt up and end up in the right place, then it's a done deal.
I don't stand to earn a dollar from either of my projects, so this offer is simply for people that want to jump in on a revised wheel done correctly. If the guy on Facebook has an good product, I might reach out to him. I've got three V1 wheels here (in addition to my own wheel) to provide to vendors as needed.
The four things I'm pursuing on the wheel project are: reduced outer diameter, flat bottom, defined thumb notches, and additional thickness without making the grip profile round like you often see when people add padding to OEM wheels.
I got rid of Facebook 8-9 years ago when they started selling user information (I was already unhappy with the signal-to-noise ratio), so I'm not going to go look for that wheel. If you'd be so kind as to post a picture, I'd appreciate it.
There are two v1 pages on facebook one that is ran by a real doucher who happens to be on this forum for burning his car down or some ****. The other one is ran by a dude who could give two ***** if you argue with him.
