Supercharge
The dealer is in Southern California, Mark Cristopher Cadillac 909-390-2900, as far as I know I don't think so. I din't get into all the details with them, but I know they were going to charge $10K for everything.
Originally Posted by ahahnu
I mean where is the dearlership? I never heard of any dealer doing something like that.
My other question, does it void any warranty from Cadillac?
Trust me, I was shocked when they told me.
Thank you. I was kinda hoping it would be with in driving distance, but from right coast to left coast is a little too far. Maybe someone out here will be able to do it.
The whine from a magnacharger is very loud and can be heard over a performance exhaust under boost.The Pro Charger is alot quiter and you can actually hear your performance exhaust under boost.When running such a low psi,an intercooled unit does not outperform a non intercooled unit.The unit on More's car never saw a high intake air temp.Its a lot cleaner install.Other note to consider...Magnacharger you can't choose to go with an aftermarket intake or a bigger throttle body for more additional power....procharger you can.
I heard that More’s unit requires a lot more modifications and cutting.
one small modification to the radiator support to allow for intake duct clearance.
If someone does want to install a magnacharger ,More is getting one in stock.they said they would give a very good deal on.
