Switched power source for radar detector?
I have tried EVERY suggestion on all the web sites and still have to manually turn on/off my Valentine 1. I thought I had a source that powered down with the vehicle, but I guess I was just kidding myself. I also found that there is a panel behind the ashtray, so I can't get in there. I would just like to find an easily accessable power source that will go on/off with the ignition. Any ideas? When they finally print the service manuals for the '05, perhaps it will become clear. Thanks for you help.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The valentine 1 source on the FAQ DOES power down with the vehicle but it stays on a bit after you get out of the car. See the FAQ answer on the RAP system. It does take a few minutes up to 20 probably for it to go off AFTER you turn off the car.
If you are looking for another source. The cigarette lighter is a source (behind the AC unit). I have plugged into this for my Cell phone car kit and it works great. HOWEVER. you need to put in the additional FUSe (that GM left out- about $7 if your delaer wont give it to you free) and move the fuses for the cig lighter in the fuse box over to the "alternate port."
See here: http://www.cadillacfaq.com/faq/answers/accpower.html
E-mail me if you still have any questions and i will try to help.
What general area are you trying to get the wires to?
You can run it off of the orange wire coming out of pin 5 of the ignition switch. That wire is only hot in "ON/RUN". The pink wire going into the DIM (dash integration module) in pin A2 of the second connector is hot in "CRANK" and "ON/RUN".
Those are two options. Those are the first two that came to mind around the dash area.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by carpe dm
You are so right; I have tried this! ![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
i know this is a different topic, but since its similar in nature....well here goes..
I had my dell phone charger plugged nto the rear 12v plug... I left it plugged in four about two days, but i rarely used the charger itself...
Anyways, i noticed that when i di try to plug the phone it again, it didnt start charging. I plugged the charger in the on by the "ashtray", under the ac and it light up and suddenly died.
So, i checked the fuse and noticed that the appropriate fuse was blown (dude, these fuses are tiny...cant get a grip on it!! I later noticed that there was a fuse puller...WOW that was cool...now i now what 50k will get ya....lol!!)...
Anyways, i havent relplaced the fuse but has anyone have this happen. Also, since 12v plugs are still active after the ignition is off, could this of overloaded the plug therefore burning her out?
thanks in advance....
under the back seat drivers side there is a fuse panel the fuses on the lower right side of the panel are on ignition on and off when ignition is off it is very simple to run the wire under the carpeting and moulding i wired my valentine and g tech this way
weird the fuse blew.. could be a fluke.. i would only be worried if it happened again...
there are instructions on how to get power for accessory devices near the center stack: http://www.cadillacfaq.com/faq/answers/stackpower/
Reed
Reed
yeah, i haent had a fuse go yet but i havent kept the charger on all day. Im thinking that maybe the old charger was bad and shorted the circuit, but will keep this up in he air though i dont think its a big deal or recall status.
I have mine wired into the ceiling light so V1 can be permanently mounted above and to the right of mirror (have to stay off dots in windshield), and will go on and off with key switch. I had a pro do this as an extra ($30) when they were installing DVD screens in headrests and DVD unit behind rear seat armrest.
BTW, this is 4th vehicle I have had V1 hardwire set up this way and it has always worked.
The picture in the top of the link above is the underhood fuse box and shows the location of the fuses for the cig lighter...
Reed
Reed
Reed
Reed
That is a big help m8. What model fuses are these? Would this be something that I can simply pick up from RadioShack? I suppose the colored tabs are the fuse holders. I'd really appreciate some feedback on this. Thanks.
These fuses are available at ANY autoparts store and most likely radio shack too.. Pull one out and bring it in, they can help you out...
There is a little tool to help you pull them out as well. there may even be some spare fuses in the box.
Reed
Reed
Bigfeat, sorry about not replying, this thread slipped my mind.
Yeah...well, an update. I replaced the fuse and had the charger plugged in for a few days in and it still running fine. Before the fuse replacement, i replaced my charger and it appears that the charger itself was the problem.
Good luck to ya.....
