Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Who has had Rear End Problems? And what did Cadillac do to fix it???
Old 10-31-2005, 11:10 AM
  #41
obZidian's Avatar
interesting....
Just wanted to touch up on the subject. I once saw a part number for the "new" rear but still unsure which one. Will check the faq site ans see what i can find.
Im starting toi hear a whine, Or im psyching myself out in thinking im hearing a whine. Its more evident at around 23-28 mph and goes away slightly, but still there.
Im wondering if this is just tire noise, fun-flats, or is this the diff whining. It does seem to only be audible when on the throttle, though litely of course, but i have heard similar or identical whines when off the throttle.
Anyways, will get this checked out and the services managers at Braman Cadillac have been friends with me and my family for YEARS!!! My folks have always loved their caddies!! This is the (my V) 9th caddy to date, including my dad's new STS4.
So, is the new diff (06') the real thing or would i be best to find another diff carrier for example a dana?
Old 11-17-2005, 11:51 PM
  #42
Oracle's Avatar
I was at the drag strip last night and broke my rear end. I pray that I can get the newer rear end.
Old 11-17-2005, 11:54 PM
  #43
obZidian's Avatar
OOOOOOHHHHHHHH!!!!!!!!!!
That sucks!! How hard where you launching with what kind of tires/mods?
Old 11-18-2005, 12:40 PM
  #44
Oracle's Avatar
It broke on my first launch, I had severe wheel hop at about 3500 RPM's. I was using my stock tires and rims.
Old 11-23-2005, 07:46 PM
  #45
SiCk PuPpY's Avatar
Dave,
I assume you bought yours from Young Cadillac? I purchased mine from Freeway, logged just over 5,000 miles on mine and had to have the rear replaced for whining. Fortunately, It was done without issue or resistance by them (Freeway is terrific!).
The car now has just over 6,500 miles on it and the outside rears tires are worn to the wear bars. My dealership informed me that GM is replacing those as well as part of an identified rear issue. I will find out more when I go in this Friday to get my winter tires installed and chat it up with the Service manager (Dean).
Not only is the rear end weak, but it will not hold proper alignment and geometry. I am thinking that this car is yet another failure on GM's part.
Old 11-24-2005, 01:51 AM
  #46
obZidian's Avatar
interesting, im having both of these issues. The rear whines, had the fluid changed and now its gonna get schedules for a replacement. Also, my rear tires are eaten on the outer edge.
Let see what my dealer has to say since would be replaced by GM.
Old 11-26-2005, 03:05 PM
  #47
verbs's Avatar
My rear end blew after 3300 miles. Getting it replaced under warranty with the 2006 Rear end, but the dealership gave me all kinds of **** about it and claimed this hasn't happened to anyone else, and said the next one is on me.
Old 11-26-2005, 04:00 PM
  #48
formulaMARK's Avatar
I was with my friend today and he just blew another rear today. This is his 5th rear that he broke. What is the deal with the 05 or the 06 rear end?
Old 11-27-2005, 10:40 PM
  #49
Oracle's Avatar
I got a call from my dealer and I should have my new rear end later this week. They assured me that it is the STS V6 rear end.
Old 12-18-2005, 02:56 AM
  #50
dumpMyGS400ForCtsV's Avatar
Gang,
My brother is a senior exec at a one of the largest GM dealerships in the Midwest. They recently took in a CTS-V. The service manager was so hot for it that he took it out in the back lot, dumped the clutch, and immediately blew the rear end.
My bro knows I've got the hots for a CTS-V so he took some extra effort w/ the service mgr to get the scoop from GM. The story is that the rear end IS strong enough, but any rear end taking that much rear-hop abuse throws off the geometry so bad that it snaps it off.
At any rate, they had the rear end replaced with the STS-V rear end (the official replacement for broken CTS rears) and my bro says that you can definitely tell its way beefier with finned heat exchanges. They took out the CTS-V again, beat the crap out of it, and it was completely solid.
That wimpy rear end was the only thing holding me back from dumping my GS400 and now that I know the STS rear end is the right fix, I'm definitely going to go for it. I might wait to get a used '06 as they have the updated LS2 V8 along w/ the STS-V rear as standard equip. We'll see.
Old 12-18-2005, 07:15 AM
  #51
cvp33's Avatar
The 2004/2005 CTS-V's shared the same differential with SRX's and base CTS's with only minor changes. The 2006 CTS-V's and the new STS-V's have the same rear differential. The case is in fact beefed up as are the half shafts. Unfortunately I'm told the ring and pinion have not been touched. There have been no failures of 2006 rear diff's that I know of.
Signed,
Mr. 4 differentials and counting.
Old 12-19-2005, 06:34 AM
  #52
SiCk PuPpY's Avatar
Originally Posted by dumpMyGS400ForCtsV
Gang,
I've had mine replaced once already. The new one has a Diff. cover with a finned lower half. Is this the STS rear? The trouble is, we're getting a whining gear sound again...it goes back into the shop today.
Old 12-19-2005, 12:58 PM
  #53
obZidian's Avatar
check your part number.... make sure its this one PN #15793756
I believe this is the 06 V/STS-V diff that should help with the diff going south on ya.....
Old 12-19-2005, 12:59 PM
  #54
obZidian's Avatar
Im a bit confused....did you mean the "STS-V" rear?
Old 12-22-2005, 10:43 PM
  #55
eeiii's Avatar
Has anyone blown a rear end with the BMR kit on?
Old 12-23-2005, 01:53 PM
  #56
Closer_2001's Avatar
Yes - a guy on the Cadillac Website had this happen.
Old 12-24-2005, 12:27 PM
  #57
eeiii's Avatar
I have 17,000 miles on mine and no problems so far.
Old 12-27-2005, 08:42 AM
  #58
GT04CTS-V's Avatar
Well, I'm on my third differential. The first one was replaced at 2900 miles due to noise. The second one was replace at 5500 miles and was noisey and leaking. The good news is that the third diff is the new 06 model PN 15793756.
All have been covered by warranty.
GT
Old 12-28-2005, 11:55 PM
  #59
eeiii's Avatar
What do I need to do to break mine? I really want the 06. I have taking mine twice to the dealer to have them check for leaks, no luck.
Old 12-30-2005, 04:01 PM
  #60
roadracerx72's Avatar
But will wait and see what Madman is coming up with...
Quick Reply: Who has had Rear End Problems? And what did Cadillac do to fix it???
