2nd rear end
2nd rear end
3279 miles on it, the rear end will be replaced again. at 1700 miles it was howling pretty bad, so it was replaced due to excessive wear on ring and pinion gear. at 3279 miles it completely went out to the point where i would be flooring it, and going nowhere. Whats ironic, is that i have NEVER launched the car. Yes, i've hit hard second and 3rd gears, but i have not launched that car once...This is starting to get a bit frustrating
Ben
Ben
Ben
I would believe a poor ring and pinion set up is your problem. Try another dealer. If you are hitting second hard enough to get wheel hop then install an aftermarket kit to reduce the hop. Wheel hop is very tough on the rear end parts.
If you blow the rear is it a complete assembly swap like a vette or do they just rebuild the old one? Possilbe to get 4:10's on the swap, or purchase a build one and have the dealer install it?
I get all the work done at Sewell Cadillac around here in dallas. they're the "best" dealership in the city. The first time around it was a bad ring and pinion gear setup, this time the tech said he thinks i broke the half-shafts. But im stuck without my V for probobly at least the whole week since the July 4 they are closed I dont understand how it can just snap in half like that off a 2nd gear scratch! kind of sad
Ben
Ben
Originally Posted by rjgraham
This rear probem is starting to scare me, I like to drive my cars hard and the vettes I have had could take it. There has to be a solution to this issue.
BTW, for those of you with FG2, does it wheelhop as bad or worse?
Ben
That Sucks. I Am Making 500 Hp To The Wheels Right Now On Mine And Am Installing Nos To It Also This Week. I Have A 1000 Km And (knock On Wood) It Is Still Holding For Now Anyway,
Dallas
Dallas
Originally Posted by 02 Tahoe on 20s
Starting to scare you? ****...2 rear-ends in 3200 miles scares me. My car isn't even modded, and its never been launched! When I want to accelerate hard, I will feather it from about 1800-2 grand. In my humble opinion, 50,000$ worth of car shouldn't snap in half from hitting second gear with a purpose. If its supposed to do 4.6 0-60, and explodes everytime I try to do it, I want my damn money back. This is a load of horse crap, and what's more frustrating is this is the ONLY damn car on the market that happens to be exactly what I want. It looks like I'm at GM's mercy here...
Ben
Ben
class action, anyone?
Guys, I'm not a lawyer fan, but this is an unacceptable situation.
My car(2005) has 4300 miles. At 3400, I took it in, complained about the rear end clunk, and asked them to check the diff.
They measured the pinion lash at 3x spec, "checked the gear oil:OK", and were told by the area service manager(who will not talk to me) that
"it's a normal driving characteristic of the vehicle".
I do my own race car work. I put it on my lift, pulled the diff fill plug, and black lube ran out. The bottom magnetic plug was covered with grunge.
I then drained my wife's BMW 30,000 mile diff:crystal clear(yellow), just to prove a point. Took the oil and shop rag of goo to the service manager.
"Well, it's synthetic oil."
Are these supposed to be acceptable answers?
Ben
$50,000 I wish, I had to have the first one(like a dummy)and I spent $64,000
and as far as luck I have also had the a/c go out, the charging system go bad,
the radio broke, leaking waterpump, and power steering pump changed, and not to
metion that damn oil temp chime going off for the first 3 months i drove it.
oh and my mirror fell of the door.
Absolutely unacceptable. I have grown to expect this kind of ringaround from chevrolet with my tahoe's broken tranny which was apparently caused by the 20s...but thats another story. Cadillac should sure as hell not be talking back to us when we've spent 50,000$ on our cars and have to have rearend components replaced every 1500 miles. This is absolutely obsurd. There was a post that I made a few weeks back that was subject "every black cloud has its silver lining" and one of the replys was a web forum thread that had over 200 replies and 18000 views. my suggestion is to print that out and either mail it to general motors, or hand it to the owner of the dealership NOT just the service manager. Regardless, this is absolutely unacceptable.
Ben
Ben
Good lawd. Im still on my first rear, and im spraying the **** out of it. Hopefully it wont go anytime soon. There has to be a upgrade coming out soon to keep GM outta trouble with all the V owners.
