Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Nav Wont Work???
Old 02-24-2007 | 02:55 PM
BaddillaK's Avatar
Question Nav Wont Work???
Im not sure whats going on with my nav but it just doesnt want to cooperate
Symptoms
1. Right when nav disc is inserted and I press nav or go throught the main screen it says "no map disc has been loaded"
2. If I wait about 5-10 seconds and I press nav or go throught the main screen it says "Disc Initializing" that stays on for about 10seconds and goes away, but nothing comes up and if i press nav again it says "No Map DVD inserted"
3. If I wait awhile like 15 minutes and I press nav or go throught the main screen it says "No Map DVD inserted"
Things that could be causing me problems...
1. Nav disc scratched.... Fixed the disc looks like its brand new
2. Nav disc isnt the one that came with the car. Maybe I need an update??
3. Took of the onstar antena.. dont think it has anything to do with the nav but you never know...
anybody ever had a problem with there nav like this
any help would be appreciated
i really just didnt want to have my car sitting at the dealer for a couple of days while they figure that out
Old 02-24-2007 | 03:36 PM
87gnx's Avatar
Is there a nav computer on this?? If so, try a reset and see if anything changes.Not an expert,$.02.
Old 02-24-2007 | 11:52 PM
heavymetals's Avatar
Did the disc work before?
You alledge that it may not be the right one.
Post what info is printed on the disc.
Old 02-25-2007 | 01:05 AM
valdeztke's Avatar
You sound a bit uncertain about this.....which is puzzling unless you just got the car and finally decided to try out the nav- in which case it makes sense.
Has it worked in the past?
Old 02-25-2007 | 10:29 AM
nikon's Avatar
I'd start out checking the cd drive...get a dvd and try to play it...if it does'nt play, then the drive maybe dirty/fubar'd ...other than that, post whats written on the nav if it hasn't worked before.
Old 02-25-2007 | 10:37 AM
BaddillaK's Avatar
the nav disc is definetly not the original. I bought the car Used and I asked the dealer where the nav disc was at (it still had the case for it but no disc) and the guy told me that he would be able to get one for me. It is definetly a Cadillac Nav disc and it comes from a newer car apparently. By looking at the info on the cases it must come from an 05 or an 06 being the coprights are all in that range and the original that was in my car had copyrights of 02 and 03.
Old 02-25-2007 | 10:55 AM
BaddillaK's Avatar
the drive definetly works it plays dvds i just took a pic of the disc here it is
Old 02-25-2007 | 02:10 PM
The nav dvd's are not compatible accross the Cad platforms (thanks to the intern GM hired) so the CTS and the V share the same disc, but the others won't work.
PM me your address and I will send you a nav dvd to try.
check this link also:
http://www.cadillacforums.com/forums...-firmware.html
Old 02-26-2007 | 12:27 PM
nikon's Avatar
yup, lindens right, the disc you have is for the escalade/srx/ and I think will even work with other gm cars.
Old 02-26-2007 | 12:58 PM
BaddillaK's Avatar
I guess ill have to go tell the dealer so he can get me a new one.... the salesmen I dealt with is pretty good and has a very good rep at one of the most respected dealers in the area so... im sure that they will take care of me...
I had also been looking on the faq's site and was looking at the Nav disc DVD structure and I noticed that it doesnt have one file, and its the loading.kwi so i figure thats the real problem and the reason most other gm disc dont work in the cts
Old 02-26-2007 | 01:14 PM
Nav information:
https://www.gmnavdisc.com/overview.d...5771469EE9D36F
Old 02-26-2007 | 02:54 PM
valdeztke's Avatar
Mine didnt even come with a nav disk ... oh well guess the SC is much better than a nav disk
Old 02-26-2007 | 02:57 PM
BaddillaK's Avatar
nah i rather the nav disk
jk sc would be nice
Old 03-04-2007 | 12:37 AM
Well?
Did it work?
Old 03-04-2007 | 09:07 PM
BaddillaK's Avatar
didnt have a chance to check it out yet, ive been out of town for work. When I get back home Ill check and se how if it works and give you the results
Old 03-11-2007 | 05:43 PM
BaddillaK's Avatar
well i finallly got to test the disk you sent, and it still does the same as before, so I guess its time to drop it off at the dealer....
Old 03-29-2007 | 01:50 AM
Kingpin08's Avatar
my nav disk stopped working too. maybe because it's too scratched. any ideas on how to fix it? can copies be made of the disk with a dvd ripper on a computer?
Quick Reply: Nav Wont Work???
