reduced power mode
check for corrosion on all of the pins related to the tps system. Mine would throw a tps/ pedal position voltage correlation code and it was just one bad pin in the tps sensor harness.
ok still no luck.checked every wire . problem still there. also when resetting the pedal as instructions from Caddy FAQ's and someone here it won't respond.
but the car starts every time. anyone have any ideas ?
Turn car off, wait a few seconds.
Hold throttle to the floor and keep it there while trying to start the car. It won't start (try only once).
Turn off ignition.
Wait about 15 seconds.
Start car.
CEL and Reduced power mode should go off and you should be able to drive normally.
Turn off ignition.
Start car.
