Which slave cylinder do I need to put a c5 z06 clutch in the V?
I know there is a spacer offered to make the stock slave work with the z06 clutch for $60 but with 120k on the car, I'd prefer to spend the difference and get a new slave while I'm at it. Which slave will work best to put this LS6/Z06 clutch in my car?? I'm told it's different than the standard V clutch so will the C5 Z06 slave be fine or should I go with the C6 Z06/LS7 slave?
Thanks in advance fellas!
I'll post a pic when I get to the shop in a bit. The V slave is shorter. Katech and TPIS offer spacers for it to make it work with the z06 clutch but like I said, with 120k, I'd rather just spend the $100 and replace it while I'm in there. I just don't know if it's the c5 z06 slave that I need or if the C6 z06 slave will work on it...
Still looking for the answer to this if anyone knows! I know the C5 Z06 clutch will obviously work but still unsure of which new slave will bolt up and work with no issues???
Also, will i have an issue with the size of the throwout bearing? I have one that came with the kit so im assuming it would work with the longer slave that will work with the new clutch but i am not 100% sure...
Spoke with Luke at Lindsay Cadillac and he said the LS7 should work. Says he's not 100% sure but he said considering the factory slave would work with a spacer, the LS7 is a little longer so he doesn't see why it wouldn't. Just wanted to find out for sure before I spend the money ordering one. I can measure my stock one but won't be able to measure the new one until I buy it so that's my only issue.
Stock on left, new C6 GM slave on the right.
C6 base and C6 Z06 (LS7) are the same PN.
Sorry
Sorry
