04 LM7 head bolt design
We have a 04 LM7 with 706 heads in a GMC Sierra which we are pulling the heads on. Did the 5.3 make a mid year transition like the LS6 block vehicles or is the transtion more clearly defined, is there a casting number to verify which head bolts were used?
My 04 has all the same length bolts.
The middle ones aren't the ones that vary. It's the end ones in the top row if memory serves. (the row of big ones, not the little ones next to the intake)
10 total 11mm Bolts.
Early design: 8 long, 2 short in the middle row on the ends.
04-up: all 10 same length.
Pulling the middle bottom one will either be a long or a short. That's how you tell.
Middle row = the top row of the larger bolts (the ones that make a square around the cyls; not the little ones along the intake flange that don't do much of anything)
The ones in question are the 2 bolts at the ends of the upper row of large bolts(front- and rear-most); not bolts in the middle.
Those little M8 Bolts seal in the Water Jacket on the ends, all together bolt the top of the Head to the Block and make it more rigid. So yes, they have a purpose.
As I said above for those who want to argue...
Attached pics for the reading impaired. Get back to me..
The short ones, in the older engines that have them, are at THE ENDS of the head.
There's a row of 5 across the bottom, next to the exhaust, and a row of 5 kind of in the middle of the head butt closer to the intake side. Then a row of 5 across the very top next to the intake flange, which are itty bitty things, totally different from the main 10.
Those main 10 make a pattern of 4 around each cyl.
The 2 short head bolts in the first design ARE NOT in "the middle" of the head. They are at THE ENDS. On the driver's side, they are the ones IN FRONT OF cyl #1, and BEHIND cyl #7; on the top row of significant bolts (disregarding the little weenie ones that are about the same as timing cover bolts except longer).
Note carefully, they are at THE ENDS of the head, NOT "the middle". If you pull a bolt out of "the middle" of the head, it will be a long one EVERY TIME IN EVERY ENGINE. (again, disregarding the little weenie ones that are about the same as timing cover bolts except longer) If you pull ANY of the ones next to the exhaust, it will also be a long one EVERY TIME IN EVERY ENGINE. To make a valid check, one has to pull one of the bolts from the TOP ROW of significant bolts (again, disregarding the little weenie ones that are about the same as timing cover bolts except longer), either the front-most one or the rear-most one. NOT "the middle".
Stop focusing on #9 & 10 in the torque sequence, and see what I'm talking about. You stated you were quoting from "memory", and I posted pics. Done it too.
https://help.summitracing.com/knowle...SR-05187/en-us
