2007 -V back on the road
ls7 clutch and slave
transmission rebuild by Texas Drivetrain performance (great job BTW)
drain and refill the rear diff
replace the rear lower control arms
CS motor mounts
new starter
oil and filter
plugs and wires
flush the power steering system
New CS shifter
everything else seems to be fine. the transmission shifts smoother every time I put a few miles on it, so the TDP rebuild was well worth it.
The went well, after I had to saw out the old rear control arms because the bolts rusted in the bushings. I do my own alignments with home made tools and I thought I would pass along an alignment tool DIY and a how-to for aligning a Caddy. Attached.
The usual method is to shake the wheel to look for hubs going out, or a noise when that side of the car is loaded, like going around a curve. When you have one that shows runout that you can make happen with your hands you have a bearing that is gone and about had it.
Wheels can be bent too, so I usually run a dial indicator on the rim. The inside usually has a flatter surface at the bead area.
Finally,if you are tracking the car look at the transition between the hub flange and the hub center. Some folks have been reporting finding cracks there, and one driver had damage to her front end at the track when the hub flange decided to part ways with the hub center. Dye Check is the usual method for checking for this crack. Never heard of a street car having that problem.
Thanks. Hope it helps. Actually a 4-wheel alignment is easy. If you correct thrust angle first, then camber, and finally toe, you are on your way. One trick I did not write about is to shoot the laser on the wall and put a piece of tape on the wall at the laser dot. Then when you make toe changes, you know which way you want the wheel to move and you can watch. you can either have an assistant hold the camber gage on the wheel or use light bungee cords to hold the gage to the wheel.
If anyone wants the excel chart for caster multiplier, PM me with your email. .XLSX is not a supported file for upload. It is the file that i used to create that graph in the writeup.
.005-.007 lateral and .010-.013 radial at the wheels (sometimes the force of the tire bead will egg the wheel a scosch). If I put just the wheel on, and no tire, I would expect to see this a bit lower.
.020 lateral, and and .025-.030 radial at the tire
Typical high performance car specs for TIR: (total indicated runout, so max minus min, not the average)
Hub .005 max for both radial and lateral (if I saw that much on a new one I would send it back) They ought to be less than .001 new.
Wheel .040 radial and .045 lateral
Tire .050 radial and .060 lateral.
Now measuring runout on a tire is a sorcerer's game especially one that has seen the road. In the old days with bigger limits on steel wheels which were stamped and welded, (modern high speed cars have machined wheels and they ought to be dead nuts on when new), a lot of people "force-matched" wheel to tire, putting the tire high at the wheel low. Don't see anyone that even knows what that is these days in a tire shop.
For alignment purposes, the runout at the surface where you are measuring (as an average of everything that is rotating) is all that really matters but it is important for those reading that you explained it in detail.
You wouldn't feel 1/16th of an inch worth of runout in the steering wheel (probably) but you can see that if both wheel assemblies (the combination of everything rotating as a whole) where a 1/16th out on both sides, it could throw readings off appreciably.
Nice work.
Nice work.
Most runout conditions can actually be hidden with a good dynamic wheel balance, as runout will give a big 1X vibration. Certainly if the runout is within spec, the dynamic balance will absolve a lot of sin.
The wheels on my C5 track car are Speedline C5Z06 wheels and they have about .002 runout. All they have seen is track duty. That being said, there have been an "agricultural event" or two and more than one gator and curb driven over. The Caddy on the other hand has 95k miles and who knows how many potholes, curbs and tire alligators have been hit. That is where most things happen. Then there is dirt under the hub, etc.
Sadly, about the only time runout is ever checked is to silence a complaining customer and put the burden of the condition back on them. The stealerships don't do it, that would cut into the flat rate payback. How many alignment reporting sheets show the recording of runout??? A wiley techincian would at least rotate each wheel with no load and eyeball for runout. You should be able to see .040.
I thankfully got out of it just when the "report printing" laser based machines became common place but of the one laser I did use, you still went through the motions of checking runout even though you couldn't visually "see" the runout like you could with a machine that was using a light beam on a chart.
While I liked doing alignments on an optical rack because you had a better feel for what was going on, the move away from solid axle, RWD cars made the laser a requirement if you were quickly going to do 4 wheel alignments...
In other words, its all gotten "black box" and its hard to know what they're doing.
Sadly, more folks today are interested in collecting a check rather than the satisfaction of a job well done. If feels to me that it isn't "cool" to show you care these days. I get this whether it is at a restaurant, stealership, or store. Those that care ARE there, but the minority.
Cars today are black boxes to almost all users, and reliance on the experts is heavy. Mmmmm, no wonder lawyers are plentiful.
If i mess with the alignment to install something i just use two ropes criss cross them under the car and get the wheels pretty straight so i may get to the alignment shop...
