What are LT1 ported stockers, 306 cam, injectors worth
I have a set of ported stock LT1 heads. They only have maybe 500 miles on them since rebuild. New larger valves and springs good for a cc306 cam.
Cam has maybe 3000 miles
Heads have 500 miles
Red top 30lbs injectors
These parts will be removed in the next month or so.
Please tell me what you think they are worth.
I have no flow numbers. I had an engine built last year and payed extra for the porting and upgraded springs. I made 360whp with a bad mail order tune. The timing chain broke at in Aug and he had to put all new valves in them. They were back in the car in October then I put the car away. Still in there now
Stating the name of the shop who did the work may help to determine the value. Also, important info such as flow numbers , type/size of valves used, and having proof paperwork/receipts will go a long way in trying to recover decent money whenever selling them.Hope this helps. Good luck in the sell.
