Fox body 6.0 LQ4 swap
Just sold my ford engine looking at the 6.0 swap.Is there anyone in Alberta that does any work or can steer me in the right direction on the swap.I will be getting a ON3 perfromace turbo kit once they come out in a month.Thank you in advance.
I just picked up a 6.0 to swap into a 4-door Fox - 1986 Mercury Marquis.
Are you looking for someone to do it for you? If you are doing it yourself, there are several helpful threads on here dealing with the swap.
fox body swap
How are you doing with your build?are you useing the factory K member?What oil pan are you using on your ls1 swap????
I haven't had time to do anything with it. I'm using an AJE k-member. The car will be lower and haven't gotten a different pan yet...likely pick up an F-body pan.
