Carbed 5.3L Build, what to do? NOOB needs help!!!
above 5500rpm means nothing to some one who is just want ls upgrade in there vehicle. thats what it was intended for. simple
Buying the edlebrock box is absolutely pointless. It is an MSD box that has had a key feature removed. You can program an MSD box with the same pills as the edlebrock. The edlebrock box offers absolutely nothing, it is not any easier to use, it is just less capable. It costs as much as the MSD but will have half the resale value.
The only reason I can see for buying one is if you get a killer deal or if you simply don't know any better.
But to each his own.
Turd Gen Guy
450 crank hp is attainable. id bore it to 99mm (ls1 bore) get a set of pistons to make compression around 10.5-11, stock rods with upgraded bolts, stock crank. 2.5 5.3 heads should work fine, for a cam thats all up to you. id say use a 220-230 range camshaft. and your choice of intake. fast 90's are going for good prices these days. just my 0.02
Yeah definitly let me know what you think, I am still quite a ways out on mine!
As far as "being kind" is concerned, you were less than so in your comment to the one you quoted. It did not appear you were curious about what was being done with 5.3's.
