F.A.S.T. EFI TB??? 600max HP?
So $900ish is just for the Ecu & wire harness? I would still need a High pressure Fuel pump, Throttle body, 8 injectors, 2 fuel rails, Tp sensor, Idle sensor, MAP sensor, Coolant sensor....so about near $2000k for then enitre setup? hmmm Just gonna stay with the carb then
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
