Got some track times for my carbed setup!
#41
Since you are in Texas I would give Lone Star Motorsports a call.
(936)422-3461
Real good people and their carbs make alot of torque.
I have 2 of their carbs and am working on converting my
70 camaro to LS.
(936)422-3461
70 camaro to LS.
#42
Thanks man!
A little update on how things ended up going the last few times out. I only got to make a total of 9 passes and I ended up going a best of 11.37@119 with a 1.69 60' with 31 degrees of timing I was pretty happy with that. I was still trying to get the A/F right where I want it before I added more timing to it. I got the A/F where I wanted it and the trans started slipping on me so I never pushed it any harder . I ran the last race of the year in a 12.0 index class so I could baby it and just get some more seat time, but I ended up breaking out in the first round
So over the winter I'm going to be going through the trans and adding some nitrous to the mix and have some fun next year
at what rpm are u adding a full 31? Mine is currently on 32 deg starting at 3000rpm...be interesting to see what yours does on the brake... My car needs more stall has a 3600 tci and is blowing thru it on spray, I recently installed some as cast trick flow 220's and have yet to get a spray pass on them...going with a yank convertor this spring...Mine went a 7.31@96.5 n/a on drag radials 1.72 sixty no spinning at 3480 pounds...car should be running 7.0's im kinda bummed but I think its the convertor...Its such a turd out the gate, I have 4.10's and dont want to go lower I drive this thing everywhere...
#44
#47
