SV-1 with 2004R geometry corrector bracket
has anyone used an SV-1 with their 2004R transmission? i'm specifically talking about that TV cable bracket you need to use located here:
http://www.summitracing.com/parts/SUM-700202
is it compatible with the SV-1 throttle bracket?
If money permits, check out Bowtie Overdrive's kits for carbed to 200-R. They have a slick kit for seting up your TV cable correctly for carb applications. This must be set-up correctly as you know, so seek out help from a trans. friend, or a someone who has done it.
i asked patrick but he doesn't know. (not a request he gets a lot) also, the car will be spending most of its time on the street. i've used the bracket on my holley 750 too, but have found no informaion regarding its use on an SV-1. i've seen pictures of the sv-1 bracket and i don't see any reason why it couldn't be used, but i'd like to be sure before spending that kind of money on a carburetor.
anyone with any first hand experience please feel free to share.
Here is a link to the correct geometry for the TV cable connection point. There has to be a way to either use that bracket or make one.
http://www.chevyhiperformance.com/te.../photo_07.html
