Identify This Carburetor
Can anyone ID this carb? The guy I got it from said it's a 750 Double-Pumper. The body looks like a Holley D-P, but I am not sure of the CFM.
1.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_738.jpg)
2.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_740.jpg)
3.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_741.jpg)
4.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_742.jpg)
5.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_743.jpg)
6.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_744.jpg)
7.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_745.jpg)
8.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_746.jpg)
9.
1.
2.
3.
4.
5.
6.
7.
8.
9.
![](http://i63.photobucket.com/albums/h146/camaro_five0/D90_20101231_748.jpg)
Well I'm putting it on a 396, pretty stock minus some pop-up pistons (9.5:1) and ported oval port heads. I shouldn't need anything more than this carb. Thanks for the feedback!
Those air bleeds look nasty, overall the carb looks to be dirty, buy one of those gallons of carb cleaner in a paint gallon container at the parts store and start soaking stuff. Remove all the rubber pieces ahead of time so they don't get screwed up. Buy a complete carb rebuild kit...a holley preferably, the generic ones are junk in comparison.
I would find another carburetor. The problem is this carburetor does't have secondary metering blocks, and it has straight boosters. You can probably find a better carburetor on craigslist pretty easy.
Thanks for the feedback guys. Since I am new to carbs, I plan on cleaning this one up and using it just until I get the car up and running. Then, I will be constantly upgrading parts as I acquire them. The throttle on this carb was kinda sticky, so I used some WD40 on it and now it's really fast and smooth. I think the vacuum controls the other two barrels of the carb, since only the forward two barrels open when I actuate the throttle.
I'm sure I will eventually go dual pump, but for now this will get the car on the road! I have a lot of other parts I have to spend my money on before I worry about a better carb.
