Coolant Crossover Tube - Can I Toss It?
My LQ4 has the blocked coolant plugs in the back on the heads and the crossover tube with the line leading to the tb on the front. Of course not needing coolant to a tb can I install plug blocks in the front as in the back? This would help clean up the front of my motor a little. The only reason why I ask is I didn't know if this served a balancing purpose for the cooling system or did anything other then direct coolant to the tb. Thanks
This sounds like the same situation as with the LSx engines. The correct name for that line is a steam pipe. Blocking it causes at least one hot spot; it is important to just make a bypass around the throttle body and not plug it.
Ah steam pipe, thats it! I soldered the line that goes to the throttle body closed, should I have connected this back into the cooling system? Or is that not necessary just as long as both heads are connected toghether?
I believe I routed mine to the radiator. It was a convenient place to splice into. It's been a long time ago and it's too dark and cold to look right now.
This topic has been beat to death in previous threads with the answer running from absolutely not needed to absolutely have to have it or the world will stop spinning. You can search the conversions and hybrids sections if you want to throw your 2 cents into the argument.
My take away from the discussion is the vents are there to help get the last of the air out of the top of the engine. This is needed on LS motors since unlike the first gen motors the radiator hose is not plumbed into the highest point on the motor.
There are quite a number of people who do delete the vents completely. If you do that you just need to make sure you get all the air out of the motor when filling the coolant system. Not hard to do IMO.
The fact there are numerous motors running without them with no problems tells me they are not “needed”. However, as someone pointed out in the previous thread, it doesn’t take much to plumb them into some other point in the cooling system. So why not hook them up for peace of mind? Especially if you let a commercial shop work on your car.
If you have an older motor that connects all 4 vents, then I would think most people would agree you can do what GM did with the LS6 and beyond motors and block off the rear vents.
There are at least a half dozen places you can run the vents. Just make sure it is into a pressurized part of the cooling system. Amazing the number of people who have tried to plumb the vents into the radiator overflow bottle.
Thanks for the info guys, I was wondering why my vent blocked did not casue any issues.
A) My upper hose goes above the vent, the vent isnt the highest point in the system.
B)Most of all I purged all of the air out of the system which would eliminate the need for this.
This isn't my biggest issue, but I was thinking about changing it this winter. Something else I am looking into redoing is my breather/ PCV lines, but that is another comletely different discussion.
Thanks for the help, its all in the details.
