Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Newbie
Old Jan 23, 2011 | 06:27 PM
70shortwide's Avatar
Default Newbie
alright guys im a newbie to the ls world. selling my bbc to build a ls6 i just picked up yesterday. its just a short block (roating assembly, cam, timing chain, and block). anyway, i will be leaving bottom end stock and im looking to make 550 to 600 n/a then throw a 150 shot or so on it. the spray might be a little much so its optional. i am having trouble finding which heads would be the best to use now and still have some power left in them later? thanks for the help.
Old Jan 23, 2011 | 06:44 PM
ZONES89RS's Avatar
In-Zane Moderator
So, you are putting a carb on the engine?
Old Jan 23, 2011 | 07:20 PM
vetteboy99's Avatar
Welcome! Trickflow 215cc Heads with VRX5 cam is a great combination and give around 500rwhp on a ls6. But Kooks ( I think kooks) headers are required.
Old Jan 23, 2011 | 07:33 PM
yea it will be carbed.
i checked those heads out the numbers look good.
there are so many different brands out there i never heard of so thought i would ask yall before i decided.
Old Jan 23, 2011 | 07:36 PM
ZONES89RS's Avatar
In-Zane Moderator
Ok, you didn't mention what induction you will be using.
Old Jan 23, 2011 | 08:48 PM
are kooks headers special? other than maybe primary size.
Old Jan 23, 2011 | 09:34 PM
NemeSS's Avatar
AFR 225 are also good candidates for your goal. just use whatever best headers that fit correct. even if have to make yourself.
Old Jan 23, 2011 | 09:48 PM
vetteboy99's Avatar
Kooks headers and exhaust is the ****! Do some more research on TF heads and AFR, those both are top notch.
Old Jan 23, 2011 | 10:12 PM
Well cant afford afr and the tf 220 springs are only good to 600 lift
Old Jan 23, 2011 | 10:21 PM
Are the patriots a good set?
Old Jan 23, 2011 | 10:23 PM
Luke_PCScarbs's Avatar
Heard some good things about some of the PRC heads that Texas-Speed sell. Good luck with the combo and welcome to the board!
Old Jan 24, 2011 | 07:34 AM
Yea i was thinkin bout gettin the stage 2 heads
Old Jan 24, 2011 | 12:44 PM
How big of a cam can u go without worrying bout piston to valve clearance?
Old Jan 24, 2011 | 03:12 PM
vetteboy99's Avatar
I believe 228r TSR cam. If I'm wrong, please don't make a big deal out of it.
Old Jan 24, 2011 | 05:07 PM
thats a fairly small cam. it has a z06 cam in it now so that wouldnt be much bigger. so for my sake i hope your wrong. hahaha.
