single or dualplane w fast EZ efi
for the record, i done think i will ever put a tire on that car that will hook at the track. thats not what this particular build is about. i am wanting a fast, well balanced street cruizer. my big concern on the intake is mainly hwy long haul driving. with the lockup converter in my trany, im thinking a cruize rpm around 2000-2200rpms at 70mph (i havent done the math on it, but that should be pretty close). i havent seen any #s on dyno pulls at that low an rpm. i just dont want to stumble and fight with the car for 200-300 miles because my intake doesnt match my cam.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
The problem isn't going to be the intake not matching the cam so much as too much cam itself.
Your cam is fairly conservative, roughly equivalent duration as the GM hot cam but with much more lift. I can't imagine you having a worry with either intake. Your long tubes will help also.
I'm running an LS2 with stock LS6 cam, single plane GMPP intake, cathedral port heads and shorty headers on a 2500# car. With a 3.54 rear, 0.64 OD trans and 25.5 in tire I'm in 5th gear by 35 mph, car pulls smoothly from 1500 RPM. I can drive all day long and never go over 2000 RPM. Shifting is ofen optional. Yours should be even smoother with the extra cubes and EFI.
And even with your wider tire and 800 extra pounds, my guess is you too will have traction "problems" at low speeds. Quite the problem to have I'm here to tell you.
Speedtigger has a very good point. The 25-30 lbs-ft of torque may be on the conservative side. Super Chevy in Feb of 2009 did a comparison of the single plane and the dual plane intakes in a 6.0l LS engine. Down at 3,200 rpm, the dual-plane intake offered an extra 44 lbs-ft of torque. The single-plane took over from 4,800 rpm on up, bettering the dual-plane by 10- to 12-hp. The decision comes down to where you want your power. There is no question, 44 lbs-ft of torque will be noticeable if you drive on the street.
This ez Efi thing keeps looking better and better. I wonder how it does under pressure? Like 10-15psig
I see that it's supposed to handle up to 600bhp n/a but really haven't seen advertised to handle a boosted engine. I can build a 600 n/a engine . But won't bother with ez Efi for that. Just keep Thr carb for that level
I'm interested to see what it can support under boost and with upgraded injectors. It looks like it uses 4 low impendance injectors on rails. Idk they may be high impedance. But the built in wb02 used makes it really attractive for forced induction
I've been researching the blow thru prices of carbs and This ez Efi kit is comparable in price to a proper built blow thru carb from pro systems or csu
The carb I'm gonna need is priced around 1300$
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
The FAST EFi specifically mentions it is not to be used for boost. Look through some of the articles linked earlier, they explain why.
Holley makes a system with similar claims.
Yea. I saw the pro products does accept the use of boost. However it looks significantly different from the fast. The tb for example. On the fast it's clear it uses rails with injectors
and the pro products looks like a carb like housing thing. With a log. They both use wb02 sensors built in. And the fast looks like it comes witha handheld tuner device.
I don't see why fast didn't give it psig capability?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
So I guess the injectors are located inside the housing in the pro products tb.
I'm interested in this thing for forced induction. Guess I'm gonna keep researching
Iirc pro products used to be a sponsor here some time back. But idk if they still are. A rep used to answer alot and any questions about pro products. But no more I guess
I'll let you guys know how the EZ-EFI turns out on my LY6 cammed '69 442 as pictured below. Using all FAST stuff...EZ-EFI, EZ-TCU, MSD 6012 and SPAL fan controls.
![](http://i908.photobucket.com/albums/ac289/Bandit79403Dave/1969%20Cutlass%20W31/IMG_8959.jpg)
Thanks,
Dave
Thanks,
Dave
#32
#34
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Thanks for the kind words!
Dave
#35
Why the interest in the GMPP dual plane and not an Edelbrock???
I am a dual plane guy. With all the extra torque you may have a traction problem on the line but once you are rolling and hit 2nd gear it will pull like a freight train. Torque and traction win on the street. Any vehicle with a decent converter and non-drag type tires is going to have a traction problem.
#36
I am a dual plane guy. With all the extra torque you may have a traction problem on the line but once you are rolling and hit 2nd gear it will pull like a freight train. Torque and traction win on the street. Any vehicle with a large converter and non-drag type tires is going to have a traction problem.
