Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
6010 rev limit
Old Mar 23, 2011 | 10:07 PM
Paul57's Avatar
Default 6010 rev limit
Please correct me if I am wrong, but it is my understanding that the 6010 has a rev limit setting??
Does anyone know the setting from MSD??
Is it easy to change??
Old Mar 23, 2011 | 10:51 PM
85LSburb's Avatar
Yes it has a rev limit. Mine was 5500 form factory. It is very easy to set. It is on the right hand side when you hook the box to your computer. In the white colums. Says rev limiter and you just hit the drop down button and select what speed you want. Think it goes to 12500 rpm. Have mine set at 5000 to keep self from doing something i ought to not to.
Old Mar 23, 2011 | 11:24 PM
ZONES89RS's Avatar
In-Zane Moderator
Mine was at 5500 also, i set it to 6500, then 6800, then 7100, then 7200 as i was tuning and getting it where it wants to be. At 5500, with a cam, the party is just getting started.
Old Mar 24, 2011 | 08:44 AM
hornerhotrods's Avatar
OH YEA! wind that thing up there and watch it fly
Old Mar 24, 2011 | 08:13 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Yup it's 5500. When I switched to the 6010 I took the car out for a "test drive" and almost went through the windshield when it hit the limiter. I immediately went back, set it to 7500 and had a huge smile on my face after the second "test drive"
Old Apr 3, 2011 | 11:03 PM
K9Kev's Avatar
LMAO !!
I can soooo identify
Old Apr 29, 2015 | 01:44 AM
KitsBeach's Avatar
Bringing this up again to ask if the stock msd rev limiter exists if you have one of their curve chips in.?
Ours seem to crap out at pretty low revs but we were using one of the curve chips.
Most of the curve chips say they will add advance to 6100 RPM or above, but I am wondering if the MSD box itself has a limiter in it. We haven't hooked up to a laptop and don't want to.
Old Apr 29, 2015 | 03:39 AM
ZONES89RS's Avatar
In-Zane Moderator
Mine had it at 5500 when I got my first one, every one since then I would program it before it even fired up the first time.
Old Apr 29, 2015 | 10:02 AM
KitsBeach's Avatar
If you program it do you know it the curve chip overrides it.?
Or do you know if the curve chip has a higher rev limit or the 5500 limit.?
We are trying to figure out why our street stock oval track was crapping out. We had one of the chips in.
Old Apr 29, 2015 | 10:41 AM
KitsBeach's Avatar
Post #23 on this other thread says the limiter is not on the pills (curve chips). Can anyone confirm that.?
https://ls1tech.com/forums/conversio...l#post11168512
Old Apr 29, 2015 | 12:29 PM
ZONES89RS's Avatar
In-Zane Moderator
Hook a lap top up and see what it says. Will run better, way better, with your own tune anyway.
Old Apr 29, 2015 | 04:14 PM
KitsBeach's Avatar
Yes we will hook up a laptop and see what it says and change the rev limit to something like 6800 (or a bit higher).
Unfortunately our track just allowed the use of LS engines in street stock and one of the rules is they only allow the MSD boxes with a chip. No custom tunes.
I know I know it is nuts and really easy for people to cheat on that (just boot up without the chip and then stick it in). But the traditionalists think that these LS motors are black magic and this was the only way to get them in. What is happening in this class is that people are spending $7,500 on blueprinted small block chevies that are technically "stock". So they are allowing junkyard LS motors welded shut so they can't be modified. Hopefully it will make the class more affordable to run in.
Ken
Old Apr 30, 2015 | 08:25 PM
ZONES89RS's Avatar
In-Zane Moderator
How does one weld a engine shut?
Old Apr 30, 2015 | 08:54 PM
KitsBeach's Avatar
They just put a weld on a head bolt and the timing cover, and even seal the rocker covers up. So it really is a junkyard LS..!!
I'll try and post a couple pictures next time I'm near the car.
Old May 2, 2015 | 06:24 AM
Doug G's Avatar
Old May 2, 2015 | 08:04 AM
TTur1996's Avatar
Just read the directions again to make sure. And while it doesn't specifically say. It appears that the chips only affect the timing. All the rpm settings still need to be set with the laptop. If you spraying it, the retard will have to be set as well, being the default on it is 10 degrees. Also it looks like you may have to run a map sensor if you want to take advantage of that feature. Msd told me that if you don't plug in a map sensor that it does not affect the timing. That's if you don't want to run one. The map curve is the same in all the chips.
Old May 5, 2015 | 06:27 AM
Pop N Wood's Avatar
Full disclosure, if you don't plug in a MAP sensor it will see zero absolute pressure (0 PSIa) and dial in the max vac advance in the table. So in the case of the 6010 above it will add 6° to all of your timing numbers. The 6012 box for the 58x reluctors adds something like 20°
If you aren't running a MAP than zero out the MAP table. My suggestion is run a MAP.
