Return line?
This link dicusses it in depth. Their numbers as far as HP rating and pump/line size are pretty conservative. I see guys on here with set ups that support more HP than their suggestion recommend.
http://www.centuryperformance.com/fu...e-spg-140.html
Funny that you mention that. Before I started my swap, I took the 65 to the track to get a baseline. Vapor lock on the first pass. She shut down like I turned off the key mid-track. I won't miss that feature.
Anyways, I've been mulling over the idea of using an EFI tank with an in tank pump. Is this possible for a carb'd application if I use a regulator up front to dial down the pressure? Also, would I be able to use the stock fuel line and return line or would I need something for the increased pressure? I'm just a little confused if the actual fuel pressure will be whatever the EFI pump puts out until it gets to the regulator and is dialed down or is this false? Totally lost on this one, not much experience rigging up fuel systems...I'd like to keep the stock tank and use the electric pump I've already got, but just worried about starving it or improper functioning due to mounting location.
Mallory makes a regulator, called a 3 port return style. #4309. I had a 255in tank on my mustang and converted to a carb and used all my existing stuff. Just spliced a switch into the factory wiring, so I could turn the pump off and on whenever.
Orme Bros in Northridge, CA sells the compression fittings for the factory lines to convert it to -6 AN. Then you run -6 lines in and out of the regulator.
I cut the factory lines and put the fittings right on the lines... I can't the pictures of the lines with the fittings.... might be on my old hd.
I just ran pushlock blue hose for the feed and return and cheapo black fuel line for the carb feed, but you can run individual lines to the carb.
I have used this regulator with Weldon f/i pumps as well.
It works and is cheap to do. Recomend adding a oil pressure shut off saved the motor once when the greese zert on the ball joint poked a hole in the remote filter line.
Tim
Nothing is hooked up yet up front but I really kind of feel dumb for not recognizing this earlier, and now might have to go back and redo some of this stuff I thought I had complete. Be easy I'm learning and this is a slow process.
