94 mustang 6.0
just finish my 2nd mustang swap. 6.0/th350, 750 holley dp with 3.27 posi trac. flow master exhaust with longtubes. i used the ford alt and ac from a v6. also used factory ford shifter and trans mount and xmember in factory location. i even used the truck oil pan without any mods.it hangs about an inch below kmember.
http://www.youtube.com/watch?v=QYGYyusKNEM
http://www.youtube.com/watch?v=fpPhtRfXmus
http://www.youtube.com/watch?v=LLBmoyJ1VI4
http://www.youtube.com/watch?v=xt312mtuRrE
Last edited by bigchief52780; 06-30-2011 at 11:00 AM. Reason: videos would not load
made them. they sort of look like s10 swap mounts. my mounts are slotted on motor side and frame side so you can slide the motor and mount back and forth. they bolt to the fram with bolts thru the mounts. i will try to get pics. all wiring is still run thru computer for now. oil, temp, voltage, fuel, and fans still work like usual. you can still use ford wiring harness. just remove efi wires but leave gauges, starter, and alternator connections. if you use ford harness thru ecu, make sure to use trans harness as well. you will need the box on side of trans. it contains the neutral safety switch. your car will not crank without it unless you tap into ingition wiring in column. for fuel, the eerc or whatever its called right in front of the fan contains a green and yellow wire that will need to be tapped into. i ran my to a oil pressure safety switch.
I am installing a ls1 in a 95 v6 car. Is that a stock hood? I am thinking about going carb,but I don,t want to run a cowl hood.I am useing an aje kmember. Your car looks great!!!
