Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
lookin advice with 408 with 6010msd
Old 07-23-2011 | 09:13 PM
408lq4's Avatar
Default lookin advice with 408 with 6010msd
i am new to carbs. i have a 408 with 15 to 1 compression. i have a 1050 quickfuel running e85. 624 lift cam wit 250 duro. looking some advice on start timing, idle timing, and wot timing. and if there anything i need to know using the msd 6010 thanks in advance
Old 07-23-2011 | 09:28 PM
3pedals's Avatar
EDIT I just noticed E85, I've never messed with that stuff, so I erased my post, as it was for gas
Old 07-24-2011 | 10:27 AM
408lq4's Avatar
anyone got any advice
Old 07-24-2011 | 11:28 AM
xpndbl3's Avatar
very small cam for that much compression IMO. Anyways, it would probably like 32-38 across the board from idle to rev limiter.
Try 14 degrees timing from 0-500 rpm for cranking, then just lock it out.
Old 07-25-2011 | 09:24 PM
408lq4's Avatar
we can only have a 625 lift cam or less for the class i am running. i am new to the msd stuff so how do u lock it out like u spoke of?
Old 07-25-2011 | 11:06 PM
ZONES89RS's Avatar
In-Zane Moderator
The duration is what is small, for that cubes it is small actually. But he says "lock it out" like running it flat across the board on the tuning software. Set the timing for 14 initial at zero degrees, then ramp to 36-38 all in by 2000 and run it flat out same timing across the timing board.
Old 07-26-2011 | 04:23 PM
Tireburnin's Avatar
I don't run anywhere near that much timing and mine is 13:1 compression.
Old 07-26-2011 | 08:23 PM
S10xGN's Avatar
The OP is running E85, are you?
Old 07-26-2011 | 08:55 PM
408lq4's Avatar
yes i am gonna ran e85. also i bout the msd 6010 from summit and it said i needed part number 60101 witch is the wiring harness. but i think it cam with the msd box. soo timing i need to start it at 14 degrees from 0 then ramp it to what being i am running e85 also what should be my air fuel ratio on wot being i am running e85 thanks for all the help
Old 07-26-2011 | 09:02 PM
Tireburnin's Avatar
Yes, I am running E85. I made over 700hp NA with 30-32 degrees of timing. Links are in my signature.
I'm not saying 36-38 won't work, just that the original poster should consider starting lower and bumping the timing as the sparkplugs allow (read them!).
Old 07-26-2011 | 10:44 PM
xpndbl3's Avatar
you need to change the settings on the wideband for E85 last I checked on the innovate and the AEM ones. Not sure what model you're running, also it's always smart to start low and bump it 2 degrees at a time reading plugs, thus my comment earlier that it might like 32-38 total. I started at 28 and kept adding until I hit 35, that's what the motor wanted going by the ground strap.
Old 07-27-2011 | 11:14 AM
newschool72's Avatar
wouldnt it be smart to pull timing out at the upper rpms to extend the powerband?
Old 07-27-2011 | 11:20 AM
xpndbl3's Avatar
you're tuning for max mph at the big end, wherever that might be
Old 07-27-2011 | 11:44 AM
thats why i thought pulling alittle out at upper rpm might be a good idea. with traditional sbc engines. advancing the timing usually gives better 60 ft times and retarding the timing more mph. with an advanced timing system like the msd 6010 or 6012 you should be able to do both . ramped up at lower rpm with a gradual retard as rpm climbs. am i the retarded one or does that make sense?
Old 07-27-2011 | 11:52 AM
xpndbl3's Avatar
with a big enough converter, when is the motor ever at low rpms
Old 07-27-2011 | 12:17 PM
true that! but it does make sense, right?
Old 07-27-2011 | 12:24 PM
xpndbl3's Avatar
only time i see a few degrees pulled is a couple hundred rpm around the true stall speed, since that's when the motor is under the most load
