Nitrous questions with a carb 5.3....6010 tune help
I have a 2001 5.3 in a 95' rcsb s10. First off i have ordered the NX hitman plate kit gonna spray 100. What plugs are u using? Gap? And i would love to see some 6010 tunes also. Thanks .....mods in sig.
You can get buy with a tr6..which is a projected tip..me if im spraying i wont run a projected tip..so i would have br6fs in the motor for that shot size..its the same heat range as a tr6..if you get over a 150 shot you can try then 7s an 8s to see what the motor likes.
