Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
What Cam for a 6.0????
Old 07-25-2011, 09:28 PM
dealrcn's Avatar
Default What Cam for a 6.0????
I'm building a 6.0 with LS3 heads. I have a set of PSI behive springs that are good to .625 lift. What cam would be good for a pro street pickup setup with 3600 stall 350th and 3:70 gears in a 9 inch. I have a 780 custom built vacuum secondary holley and victor jr intake. Looking for a cam that is good for street and strip. Rough idle would be ok but I do want to have a/c as a option. What do you guys think???
Old 07-25-2011, 10:02 PM
In-Zane Moderator
ZONES89RS's Avatar
A large split on a 110 or so would do pretty well, 226 on the intake and 242 on the exhaust with just over .600 lift. Would chop and have well rounded power.
Old 07-25-2011, 10:25 PM
newschool72's Avatar
agreed...... power brakes? i know everybody says go with a venders custom grind, but if u do the research comps lsr grinds are tough to beat with the L92s if u want some lope at idle id go for something in the 220s/240s at .050 and 620s lift on 111/112. should give an lopey idle with good street manners and plenty of stability for power brakes. just my .02
Old 07-26-2011, 03:08 PM
xpndbl3's Avatar
dump that vacuum secondary carb and run a mechanical secondary if you want all out power, that thing will be a restriction since the rear will never open up 100%
Old 07-26-2011, 08:12 PM
dealrcn's Avatar
What brand of cam should I go with? What about the PSI valve springs as far as quality and durability? Can you go up to. 617/.624 lift with .625 max lift springs?
Old 07-26-2011, 08:22 PM
ive always had good luck with comp cams. big fan of the LSR series. as far as springs go, i always go with the manufacters recommendation .they have done the research and know what works with their lobes.to me any other spring is a crap shoot. good luck with your build!
Old 07-26-2011, 09:36 PM
stinkybutt's Avatar
Be c arefull on the cam selection if you are using stock pistons. Unless you measure valve to piston clearance and flycut you might need a diferent cam.
Aleck
Old 07-27-2011, 08:46 PM
In-Zane Moderator
ZONES89RS's Avatar
Check PTV regardless i say.
Old 07-29-2011, 01:51 PM
dealrcn's Avatar
Do you guys know of a cam that will work with stock pistons? Trying to go as big as possible on lift without having to notch the pistons.
Old 07-29-2011, 06:47 PM
topbrent's Avatar
What is the weight of your truck? Don't want to overcam and make it a pig.
For your goals, combo and desire to not notch the pistons, something like the GM ASA Hot cam is a good choice.
.525/.525 226/236 110LSA
The 110LSA will definitely work well with a carb setup and will operate without any valvetrain problems.
Yes, there are probably better choices, but the ASA is a solid performer within your parameters.
Easy 530+ HP with the ASA Hot Cam.
- allblowedup on this board has tested it at 560hp in the CT525.
Originally Posted by allblowdup
the ct525 is a carbed ls3. They make 560 hp@6500 and 490ftlb@5350 on pump gas so ya they are a good motor with a carb and the proper cam.
Call one of the vendors on this board for a custom spec cam, Engine Power Systems, Texas Speed, Pat G, Rapid Motorsports, ect.
http://www.youtube.com/watch?v=b3OMxvW802k
Old 07-29-2011, 08:04 PM
dealrcn's Avatar
Ok talked to a fellow at Comp. He speced me a cam 54-470-11 for my pickup and said I wouldn't have to notch anything and clearances should be good. My truck weighs about 3600 lb's. This cam he speced me has 235/251 at .050 and .621/.624 lift with a 109 degree centerline. This sounds like a whole lot of cam for a streetable setup. This is not goona be a daily driver but I do want to be able to drive it to town for burger all along. I want a good well rounded setup for a pro street feel and sound. Do you guys think this is too much cam? I'm so use to a gen 1 small block so these numbers look huge to me for occasional street use.
Old 07-29-2011, 08:28 PM
topbrent's Avatar
That 54-470-11 comp cam has a pretty wide LSA at 113°. That 109° is the installed intake centerline, not the lsa.
If it were me, I would run something with a tighter LSA than 113° on a carbed 6.0 at 3600+lbs.
For little or no extra money, one of the good guys on this board can spec you a custom cam designed for a carb, that will certainly make more power than any of the catalog cams which are usually designed for fuel injected motors.
However, TXoldskool is running the Comp LSR Cam (223/231 .610/.617) 112 LSA 54-457-11 in his LY6 68 pickup truck (6.0 l92 heads) and has been very pleased.
Old 07-29-2011, 08:39 PM
dealrcn's Avatar
Ok tell me why you say that.
Old 07-30-2011, 12:04 AM
xpndbl3's Avatar
call Geoff at EPS, engine power systems in texas, he's the man when it comes to carb cams, I am extremely happy with what he spec'd me.
Old 07-30-2011, 07:10 AM
dealrcn's Avatar
I really appreciate all the info and advice. I will call these suggested folks next week.
Old 08-07-2011, 09:57 PM
72VenturaII's Avatar
I agree 'cause I happen to have a real new 750 double pumper for sale.
Old 08-21-2011, 01:15 AM
1961ba427's Avatar
I'm very interested to see how this works out for you. Please keep us updated on it. Especially what you end up with for ptv clearance.
(To everyone who says "always check ptv clearance" : Of course this needs to be done, but it would be nice to have a good idea of what will fit so I'm not buying a cam only to find out it won't work, then having to sell it and take a huge loss.)
Old 08-21-2011, 10:40 AM
Paul57's Avatar
I have an EPS cam for my 57 Chevy Truck...226, 230...598, 600...111 LSA, 107 ICL. Unfortunately, I haven't started the motor yet but I am suppose to be able to shift at 6000 according to my spec expert (Pat G). There are a few posts about the EPS cams putting down some good numbers...custom is the way to go!!!
Old 08-21-2011, 10:42 AM
Paul57's Avatar
I believe duration is more hazardous than lift when it comes to PTV clearance.
Old 08-21-2011, 08:42 PM
Prorac1's Avatar
I think the PTV issue is more about lobe seperation AND duration IIRC. Eric L
Quick Reply: What Cam for a 6.0????
