Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Need some help with the conversion
Old Oct 13, 2011 | 12:02 AM
TheRockHardman's Avatar
Default Need some help with the conversion
Over the winter i plan on converting my ls1 to carb. I know i need a intake with a msd box. Which one will i need? My car is going to be strickly for track use only so i need one that can take the rpms. Also what else do i need to make the conversion over to carbureted? While im doing to the conversion im going to change cam and the heads. Which cam and heads work well with this? Would the trex cam be good? Im trying to get my car into the tens by doing this. So i need one of the biggest cam and heads that match. I would appreciate if anyone can help me. Thank you
Old Oct 13, 2011 | 06:50 AM
bigchief52780's Avatar
msd 6010 box. go with some l92 or ls3. either of edelbrock victor single plan intakes or gm performance one should work good with these heads. cam wise, you want to get a custom one for your intended use.
Old Oct 13, 2011 | 07:23 AM
70shortwide's Avatar
the l92 heads wont work on a ls1. the bore is not big enough.
Old Oct 13, 2011 | 02:45 PM
ZONES89RS's Avatar
In-Zane Moderator
Ported and polished 243 heads with a Trex might get you there, it has for allot of people, but fly cutting may or may not be needed, the PTV has to be checked.
Old Oct 13, 2011 | 03:33 PM
flyin's Avatar
For my tastes, I'd like to see a combo with the Speed Inc SI7 cam, TEA prepped Trick Flow 215's and a Super Victor.
You will need an carb adjustable fuel pressure regulator to get your fuel pressure down to 7psi for the carb. Either that, or change your entire fuel system to a carb setup.
Old Oct 13, 2011 | 03:39 PM
ZONES89RS's Avatar
In-Zane Moderator
The Aeromotive high pressure carb reg should work fine, he will need to adapt it to work with the stock lines. Then hot wire the pump to key/switch on, no biggie.
Old Oct 14, 2011 | 08:12 AM
I plan on doing a new fuel system.. different tank too so less weight. I just need to decide on what heads and.cam I want. I was thinking the trex with patriot heads with the package from.thunder racing?
Old Oct 14, 2011 | 12:03 PM
ZONES89RS's Avatar
In-Zane Moderator
Will work well, but there are heads that out do the patriot pieces easily from the builds i have seen and helped with.
Old Oct 14, 2011 | 03:19 PM
and what heads are those?
Old Oct 14, 2011 | 04:00 PM
ZONES89RS's Avatar
In-Zane Moderator
TEA ported LS6 castings. 5.3 heads that are ported, ect. That is all Patriot heads are is a LS6 casting CNCd, and they are not as good as other ported versions.
Old Oct 14, 2011 | 05:37 PM
what bran are those? and would they work with the trex cam
Old Oct 14, 2011 | 08:07 PM
ZONES89RS's Avatar
In-Zane Moderator
TEA allows you to send them castings of your choice and they work them over, great bang for the buck. Then there are other sponsors here that will see ported castings, i will look later for you when i get a chance to find a really good recommendation or two,
