Crank case Evac kit and Valley cover?
Anyone tried this?
Friend of mine doing a build was curious if it'd work, since it's a cramp for room on the valve covers with the coil packs and such. I can see why it would, but also maybe why it would not. I'm still fairly new to LS1 stuff so I figured I'd ask here for a solid answer.
Basically mount these under the intake into an after market valley cover, the same as you would on valve covers on an older motor.
![](http://www.hawaiiracing.com/shop_image/product/fe7f07ba57a9014762aa11bbd4df1dce.jpg)
"Reduces crankcase pressure throughout entire rpm range for increased piston ring seal, reduced intake charge contamination, and fewer oil leaks
Track and dyno tests prove increases in engine performance
Includes 2 each: Oil Separators/Breathers, Breather/Filler Cap Grommets, One-Way Check Valve and Weld-In Nipple for header collector, use with 5/8" dia. hose."
Then they plumb from the breathers down to the headers.
Also, who makes a nice smoothed valley cover for the LSx stuff using Victor jr/GMPP intakes?
