Using 6.0 in our Port City circle track car
Need to know what to expect after we start building this engine for our race car. This is our first step into the next gen engines instead of the old style engines (only one other place in the country is building "LS" race engines for circle track) so any help on how we figure what cam to use from what stock heads to run for max horsepower would be greatly appreciated. So far the motor is going to have cams, rods, pistons, intake and head work. The only thing we aren't sure of is how big we go on everything. Any help is greatly appreciated guys and gals!
Thanks,
Alex
Thanks,
Alex
Mechanical fans are mandated in most circle track classes, most circle track accessory applications are basic. I plan on only running a power steering pump and water pump if i can find a good kit, only problem being (correct me if im wrong) i think the stock pump is reverse rotation. Very interested in what you have for accessory drive setups, I am currently collecting parts for a 402 in my dirt modified.
Edelbrock has a standard rotation pump, Stewart also makes one available from Wegner. My engine has a distributor front conversion with a long Stewart pump and a pulley set-up from Wegner. I don't have any accessories on the front of the engine, using a KSE tandem pump off the bellhousing. What type of transmission/drive are you using? The only things you need to replace a 1st Gen SBC with an LS are the correct motor mounts, a crank flange adapter, and the correct headers.
I don't know if Dynatech makes modified headers for the LS yet, but I do have a set on my late model. When I talked to Schoenfeld about ordering a set they said it'd be a while because they'd have to build them, they didn't have any on the shelf. I didn't want to wait so I got the Dynatechs. I also asked Schoenfeld about doing a custom set and after I told them what I'd like to have the guy on the phone said I'd just have to talk to Doug (Schoenfeld) about that. They're only about 15-20min. from me so I guess we'll see.
Yep, some time ago I made a adapter to use mechanical fan on a stock ls water pump. Although it has to be a truck wp with the threaded pulley for stock clutch fan.
I'm working on the final versions of the drive accessories. Everything is Cnc machined 6061 for the accessory brackets and steel for the fan adapter
