Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
is this about right
Old 11-25-2011 | 08:45 AM
richard david's Avatar
Default is this about right
I have a 93 mustang coupe with a stock lq4 bottom end with unported 243 a custom eps cam and victor jr with a 850 holley and at 3200lb the car went 11.13@121.8 .dont know if im in the ballpark or do i need to do more tuning.
Old 11-25-2011 | 08:53 AM
speedtigger's Avatar
Old School Heavy
manual? automatic? How much stall and cam?
Old 11-25-2011 | 10:35 AM
Cam is 234-246 601-606 on a 109
Stall is 8" Hughes 4200
Gears are 373 with 27"×11.50 quick time pros.
Old 11-25-2011 | 10:54 AM
itsslow98's Avatar
What 60'? Id think you should be in the 10s, but you right in the ballpark.
Old 11-25-2011 | 11:04 AM
1.58 60foot. I also been told to change my timing controller it is the elderbrock by msd and I'm run the#6 chip I'm told it puts 36deg. And I only need around 29 to 30
Old 11-25-2011 | 11:09 AM
bitterman's Avatar
With a 1.58 60' that does not sound bad at all.
Timing will for sure affect ET and will also affect your tune and A/F ratios. Tune for the highest MPH.
Also what was the air like and your altitude? 11.13@121.8 is a nice run but if your tune is off 1/10 is not a lot to gain.
Regards,
Bruce
Old 11-25-2011 | 12:36 PM
Old School Heavy
I think you have some 10s in there for sure too.
I would make this upgrade immediately. You need to be able to have complete control over your ignition. There is surely some ET in the timing.
Old 11-26-2011 | 09:36 AM
Fbodyjunkie06's Avatar
Back the timing down to 28-30 and work on the 60' and you'll be solidly in the 10's.
Quick Reply: is this about right
