What will a stock LQ9 do? Here's what.
In-Zane Moderator
Very nice man, I really like your ride, but damn, make a old small block guy jelous all day, junkyard long block, mid 12s? Lovely. To compare, my stock lq4, heads milled .030, trex, t56, at 3450 w me in, 7.1 at 97, so a 10 mph gain over yours in the 1/8th, cam only with a manual, wish I knew what it would do with a auto, Trans brake equipped and the right converter? I cannot out shift a auto, so there is surely more to be had with a setup like yours, make sure you keep us posted!
I'm on a budget so I got the tranny rebuilt locally and they said they could include a new, stock convertor in the price. The stall is 1800-2200.
another new best time
12.3 @ about 109 at the track tonight.
Was matched up against a modified 2002 Trans Am - no problem
then
Was matched up against a brand new ZR1 Corvette - PROBLEM! He must have had juice - he ran a mid 11 @ 126
(video below)
then
(video below)
I tried to keep up - that Vette was CRAZY fast
Those GN's have 8.5" rears correct ?....built, they are strong as a 12 bolt.
Get an Eaton posi, some Yukon gears, and a pair of Moser axles.....all said and done.... cheaper than a Currie/Moser/other rear.
In-Zane Moderator
Good to see the GN pick up some more!
A 8.5 10 bolt is not as strong as a 12 bolt, but it is not much weaker.
But a cold day in hell a 640 HP supercharged ls9 cannot beat a carb only 6.0 in a car that is equil weight with competant drivers, you still gave him hell off the line!
#32
GNCLONE, tell us more about your car. Is it stock suspension? I'd say your car runs very well in the quarter mile. Just wondering if your engine has any help.
#34
My car is mostly junkyard parts - it is an extreme budget build.
It has the stock 7.5 rear (this is a clone car)
it has 3.23:1 gears from an early 3rd gen T/A with factory Auburn posi
it has upper control arm relocators (people call them anti hop bars)
it has Mickey Thompson 255 50 16 Drag Radials
it has a fresh TH700R4, with Corvette Servo, better bands and sun shell
very mild new converter 1800-2200
The engine has a Holley 670 single pump dual feed
an Edelbrock/MSD Performer RPM combo
Pacesetter long tubes
3" X pipe down to 2.5" dumps
165 deg thermostat
overkill fuel supply and overkill electrical system
165 deg thermostat
#37
I had an empty engine compartment for about a year, after scrapping the n/a v6.
I narrowed my choices down to a SBC 383 stroker, a Buick 455, or an LQ4/LQ9.
I did a LOT of reading/research and came to the no-brainer conclusion that everyone else here already knew - these engines make crazy power for cheap. A know a guy with a BUILT big block Chevy (big $$$) in a car similar to mine. He is not too happy that I am running faster than him
#39
Maybe it runs where it should but I find this amazing. Gives me the itch to get started on my 69 Camaro LY6 conversion. My car is set up more as a handling cruiser than a quarter miler but this is encouraging. Hope mine runs this good!
#40
Lucked out and found a wrecked Escalade about 20 miles from me.
The LQ9 is a bit beefier than the other 3rd gen truck motors. Better rods, higher compression.
