Ls & lsx?
http://www.gmhightechperformance.com...k/viewall.html
4.250 bore x 4.500 stroke....max
LSX Bowtie Block specs and features include:
Fully CNC-machined cast iron block
True priority main oiling
6-head bolts per cylinder
Standard 4.400" bore spacing
Extra-thick Siamese cylinder bores, ready for final honing
Semi-finished, machined thicker decks
LS7-style, 6-bolt dowel-located billet main bearing caps
Wet-sump and dry-sump oiling capability
Production-style deep-skirt head bolt holes
Production bolt hole and thread sizes
Maintains production exterior accessory mounting provisions
Front motor plate mounting holes added
Additional material cast around cam bearings for greater strength
8mm exterior/interior fifth- and sixth-head bolt holes
All five cam bores machined for bearing P/N 19167218 (supplied)
Standard 0.842" lifter bores
Accommodates all LS oil pumps and oil pans
External oil pump feed (rear of block)
Main web bay-to-bay breathing holes to support greater horsepower
Includes unique cam retainer, rear cover, lifter retainers and production style replacement cam bearings For the advanced LSX competition engine builder, you will fully enjoy reading the following features of the new LSX Bowtie Block:
Front oil feed holes can be plugged/restricted for mechanical flat tappet or mechanical roller lifter applications
Can be machined safely to 9.200" deck height
Maximum 4.200" bore at .200" minimum wall thickness (naturally aspirated applications)
Head bolt holes can be machined for 1/2" studs
Cam bores can be machined to accept 60mm roller bearings
Can be machined for larger diameter lifters and/or 1.060" bronze bushings
Front oil feed lines can be plugged and external oil pump and/or aftermarket dry sump systems can be used via oil pump feed at rear of block-may be required with certain large stroke/aluminum rod combinations
Belt cam drive systems can be accommodated-some machining will be required
Front motor plate can be used for racing chassis applications (sprint car, drag racing, truck pulling, etc.)
Threaded water plugs can be used for external heaters or coolers
Extra stock for main bearing align-honed
Orange Powder Coated
Pulled from the thread:
LS7...............107
RHS...............110
Dart Billet......128
6.0L Iron.......220
LSX...............230
And like Zones said a LOT of people use the X like a wildcard symbol as a generic reference to the LS line of motors. But that is not the same as the GM LSX motors.
