Need Foxbody Mustang wiring help neutral safety switch..pic inside
Ok Guys
I'm not too familiar with solenoids, relays, and stuff. Here's a pic of what I'm gonna call the main power solenoid until someone corrects me lol.
The battery is in the trunk and has the cable coming from the battery to the left side of this thing. also on the left side terminal is a wire for the alternator, one for the old MSD setup that I need to eliminate, and something else I can't remember.
The Right side big terminal has the big wire that goes to the starter.
My big question is there are 2 small terminals (one on top that looks like it's never been used and one on bottom that has a small wire ran to it.) The small wire was ran inside the car but wasn't hooked up.
I was assuming this small terminal would run to the small terminal on the starter but I may be wrong.
My aftermarket shifter has a neutral safety switch and says to interrupt the wire that goes from the key switch to the starter with the neutral safety switch. I don't see a wire that actually runs from the switch to the starter.
What do I do.
What do I do.
